2G 2015 Acura RDX Radar Detector Mirror install
Does anyone know how to hardwire a Radar Detector to the rearview mirror? I have 3 pins and don’t know with one is 12v power both wires are grey.
https://www.mirrortap.com/
This site will help you with the hardwire, they give you different pin sizes for you. I just order mine today. Will let you know about the product when I install mine to the mirror.
sathiyan (11-02-2018)
You're Welcome.
I personally don't like to splice or tap into factory harnesses. I would suggest running a separate power and ground wire from mirror and tuck it into the headliner, then go down the A pillar to the underside of dash and use a micro fuse tap in an unused empty fuse location. I installed many dash cams this way and it is the best method.
quanaman
43
06-01-2011 10:11 AM
spinxt
34
01-12-2010 11:11 AM
