Whistling noise when window is down
I can’t be the only one that has this issue, when my driver side window is down, it makes a whistling noise as wind blows and it’s crazy. I open the other windows and it still happens, does anyone have the solution for this or know where it’s coming from?
My 2013 did it too.I had Dodge Journey that howled so bad that You thought an airplane was landing on Your roof.Just run with the temp setting on auto and enjoy filtered inside air.Mileage difference is minimal.Open the window at low speeds.
mrgold35
I had this issue with my 11 MDX and it was from the passenger side OEM wiper. Replaced with Bosch ICON wipers and no noise since. Maybe try removing one or both wipers and test drive to see if the sound goes away. The only other issues could be loose weather striping around the the door?
dubz ASPEC
09-19-2024 04:12 PM
sangamon
08-04-2005 08:52 AM
STC
1G TSX Problems & Fixes
09-18-2003 08:03 PM
