Trip Odometer reset
Trip Odometer reset
I want to see how many miles I drive on each tank of gas to track mileage. But I can't find anything in the owner's manual and nothing else is intuitive. Can someone show me how to set a trip odometer and reset? Thanks.
If you have a tech or an advanced, you can go into the settings button and then vehicle settings "Reset Trip B" and set it to reset at each fuel up, manually, or with ignition turn off.
Hope this helps!
Hope this helps!
romer (11-20-2015)
Toggle the SEL/Reset button on the steering wheel until you see the trip (A or B) on the odometer. Once you arrive at your desired trip, hold the SEL/Reset button down until it changes to 000.
Hope that helps.
Hope that helps.
romer (11-20-2015)
lmc
01-09-2016 05:25 PM
