Transmission Fluid Change at Honda OK?
Old Aug 1, 2020 | 09:05 PM
Infinite0180's Avatar
Hey,
2014 Tech. I want to get the trans fluid changed. Can i take it to Honda to save a few? Do they use the same fluid? Can i bring my own Acura fluid?
Old Aug 1, 2020 | 09:37 PM
BLEXV6's Avatar
If Honda dealer will do it, I would expect the fluids would be similar as the cars are very similar, with some adjustments for slightly altered components.
Old Aug 2, 2020 | 05:25 AM
kaehlin's Avatar
Honda dealer can do it, the fluids and transmissions are identical. If you want to bring your own, I assume the dealer would accommodate that - you should call them if you're not sure.
Old Aug 2, 2020 | 03:12 PM
csmeance's Avatar
it's the same stuff! Make sure they do a drain and refill and don't use a machine to flush the transmission! Machine flush will ruin it!
Old Aug 2, 2020 | 08:30 PM
egads's Avatar
An Acura is a Honda. In fact, many of the models of Acuras are just Hondas in other countries. The V-6 engine/trans in the RDX is very much the same in a V-6 Accord, a Pilot, A Ridgeline, An Odyssey, and an MDX. Our RDX lives on as the new Passport.
Old Aug 3, 2020 | 02:04 PM
honda wants 199$ and acura want 229$. Both seem ridiculously high but i dont feel like doing it myself in this heat and my mechanic buddy is mia these days...
Old Aug 3, 2020 | 02:13 PM
egads's Avatar
You could buy the fluid and a fresh crush washer and find an independent shop that will allow you to bring your own fluid in. Should be as easy as changing the oil.
Of course the dipstick and fill bolt seem to get deeper and deeper.
Old Aug 3, 2020 | 02:47 PM
when you drain the trans does that drain the transfer case as well? Or is that separate?
Old Aug 3, 2020 | 03:06 PM
egads's Avatar
No the AWD visions need that other service as well. If the quotes you got included that, then the prices seem OK to me.
Old Aug 3, 2020 | 03:26 PM
ok, just to get this straight. My AWD needs:
1: transmission fluid
2: transfer case fluid
3: rear diff fluid
is that correct?
Old Aug 3, 2020 | 07:24 PM
BLEXV6's Avatar
3: rear diff fluid
is that correct?
Yes.
alfadoctor
Jul 10, 2016 05:00 PM
someara23
Aug 6, 2012 09:12 AM
Braz60
Aug 3, 2012 01:34 PM
optical24
Eastern Canada
Apr 17, 2011 12:25 PM
LeeDan00
Nov 19, 2009 02:23 PM
