AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   2G RDX (2013-2018) (https://acurazine.com/forums/2g-rdx-2013-2018-404/)
-   -   Torque specs (https://acurazine.com/forums/2g-rdx-2013-2018-404/torque-specs-1012139/)
Paul365 Feb 5, 2026 05:38 AM
Torque specs
I need the torque specs for the serpentine belt tensioner. The tensioner is part number 31170-R8A-A01. The main assembly mounting bolt is a socket head cap screw part number 96600-08060-08. The only source I have found is 33 ft-lbs, but that seems way too tight for this bolt. Thanks!
EasyLoveRDX Feb 5, 2026 01:48 PM
I agree that seems high.
16 lb-ft is the official spec for the K-series tensioner which uses M8 x 1.25 bolts. I imagine the J35 tensioner is similar.
Personally I don't use a torque wrench on these - I snug them down to "quarter inch ratchet tight" and have never had an issue.
thoiboi Feb 5, 2026 05:26 PM
The M10 bolt that goes through the pulley is 33lbft , the m8 bulb is 16 per my service manual for the 3rd gen TL (shares a similar J35 engine),. I'll let others chime in for the RDX though
Paul365 Feb 5, 2026 06:02 PM
Thanks! I appreciate the help!
© 2026 MH Sub I, LLC dba Internet Brands
