Silverstart ultra / xZe
Hello,
I was thinking of replacing the low beam light with either of the ultra or xZe. It seems like the DLR is shared with the high beam so the low beam in projection housing should be used only when it comes on. I do realize that the silverstar's life is short but if it gives 25% more light, it is worth it.
Is it easy to change the low beam bulb? Anyone knows the difference between ultra and xZe?
Ultra's are brighter but not as white as xZe.
https://www.sylvania.com/en-us/produ...-products.aspx
I owned the Ultra's a few years back on my Honda Accord among a myraid of other "HID look" bulbs from PIAA.
The Ultra's are slightly brighter and slightly whiter than stock halogens. No experience with the zXe, but I'd guess they are whiter but not any brighter than stock halogens.
If I were you, I'd just get some H9 bulbs for a fraction of the price (same life span as silverstars). You'll need to file down the plastic connector to make it work.
Hello,
09-17-2015 09:01 PM
09-15-2015 06:44 PM
