Should I ignore the A14 minder? Help needed
Hello folks, a couple of days ago, an A14 service reminder popped up on my 2013 RDX screen. I know it means major timing belt, water pump and spark plugs service, and I fully understand the importance of staying on top of these services.
However, here’s a bit of background, I’m the second owner of this car. The first owner did the “4” service at a local Acura dealer at 111200km (around 70k miles) in 2019, which I have obtained a hard copy service history to proof, with all details. The car is now only at 160000km (100k miles), didn’t drive much during the pandemic, and I’ve done 3 oil changes with one transmission fluid change during the last 25k miles. I just don’t see it needs another timing belt.
so I’m just wondering, could it be that the car has reached the magical 100k mile mark, so the “4” just has to pop up for the sake of it, or there could be a legit reason that the car indeed does need it?
I appreciate all your help, thanks
Rolf65 (10-01-2023)
alexmed2002
Usually you are supposed to replace the timing belt around every 7 years/105,000 miles (168,000 km), whichever comes first. I would just ignore the service reminder and reset it during your next oil change. That light is probably programmed to come on at that mileage.
Reset it and forget it.
Alex Medeiros (09-26-2022)
All I can say is I replaced my original timing belt and belt tensioner on my Honda CR-V at 190,896 kms or 118,617 miles and the original belt was just fine and way past the "severe" replacement time/distance. No cracks even when I flipped it over and squeezed it while looking at the cogged side. Ambient temperature ranges from -30C to +30C.
yeah it sounds like they didn't reset the 4 when they did it. it's 7 years/105K typically speaking for the timing belt. if you've already done it, you can just ignore the MM and just keep an eye out on mileage/time.
Yes, that's an important reminder from Thoiboi; if you reset it, you will need to remember to do it when it *is* needed. Once you reset it after that, you can forget about it until it notifies you again, a long way down the road.
RFT!!!
Dave Kelsen
Attila the Nun, a simple girl pledged to a life of violence.
RFT!!!
Dave Kelsen
Something I've seen mechanics do is put the date and mileage of the timing belt change under the hood on the engine cover. Another way to remind you and/or your mechanic when to change the timing belt again. Also it's a good selling point if you decided to sell or trade in you RDX. If someone does the timing belt and water pump, it's a good indicator that they did the other maintenance.
Good luck.
Good luck.
Kelsen (09-28-2022)
Booked an appointment at my local Honda dealer for an oil change, I’m ready for the strange look from the service advisor, they must be thinking this guy cheaped out on timing service.
I’ll remind myself to do the 4 service when the car hits around quarter million kms, if I still had it by then.
Thank you, folks
Thank you, folks
VisualEchos
11-18-2021 05:43 PM
