Service Minder Reset ?
A recent post got me to thinking... When I did my oil change a while back, I did it before the reminder light came on. I also reset the system so it was back to 100%. My question is; by resetting the oil interval, does this mess up the other service info, i.e. When to change the air filter or transmission fluid etc? My guess is that it doesn't and it should be able to keep it all straight, but then again, some of Acura's "software" has been a bit dicey at best![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Thx
Thx
After your A1 service generally comes your B1. If you reset your A1, then your next service (in about 7k miles from reset) will be your B1 and so forth.
If you do an unneeded oil change out of cycle then DON'T reset anything.
Well mine is probably all screwed up then. After my first oil change I reset it and last month after my "fall service special" they reset it. I've changed my cabin filter and I need to change the air filter.
