RDX Factory Service Manual Requests
Old Dec 16, 2021 | 11:29 AM
  #281
wsw's Avatar
wsw
Originally Posted by cDevil
Hi Dave,
Thank you for your hard work here. If available, please share the installation instructions for '72147-TX4-A61' for this part.
If you have a 2016 the instructions are on page 380 of the Owners Manual.
Old Dec 16, 2021 | 09:21 PM
  #282
cDevil's Avatar
Must have slipped my mind to write down the model I am requesting the instructions for, apologies. The part number I mentioned, is for the remote engine starter kit for the 2017 RDX AWD Tech. BTW, I looked up page 380 on the 2016 owner's manual and it had instructions on how to change the key fob battery.
Old Dec 17, 2021 | 07:23 AM
  #283
wsw's Avatar
wsw
Yep, that's because the part number that you asked Dave for installation instructions for, "72147-TX4-A61" in your post #280 is the key fob. The only thing that you can install on the key fob is the battery, hence the referral to the battery installation instructions for the "72147-TX4-A61". Good luck on the remote engine starter kit!!
https://www.acurapartswarehouse.com/...7-tx4-a61.html
Old Dec 17, 2021 | 03:22 PM
  #284
finnigan's Avatar
I asked awhile bach for the same thing on a 2015. The install is lengthy but reasonible easy with a full set of instructions. The main issue is your rdx still will need to have the remote start setup in the car. Dealer or someone with a quality scan tool. Not the over the counter code readers, it won't work for you. I went after market after reading the process to install oem.
Old Dec 19, 2021 | 06:47 PM
  #285
cDevil's Avatar
Since my local Acura dealership provided me with that part number, I convinced myself that it includes the key fob and the required kit to fully install the remote engine in my car. Thank you a lot for pointing that out.
Old Dec 19, 2021 | 06:48 PM
  #286
cDevil's Avatar
Agree! I am looking into aftermarket solutions than the OEM.
Old Dec 22, 2021 | 01:22 PM
  #287
SimmerDown's Avatar
Serpentine belt tensioner
Hello, I have skimmed the entire forum and don’t believe anyone has requested this yet - is there a manual for replacing the auto tensioner pulley ASSEMBLY on a 2017 rdx for the drive/serpentine belt? i see replacing the serpentine belt itself, but haven’t seen anything for replacing the tensioner pulley assembly. If anyone knows approximately when the assembly needs to be replaced that would also be helpful. Thank you very much in advance if you can help, apologies if I’ve missed it, and either way Merry Christmas!
Old Jan 27, 2022 | 03:23 PM
  #288
RayNA's Avatar
Thank you very much for your hard work, this is an amazing thread.
My 2013 RDX left rear door power window is stuck closed and it seems there's something wrong with the motor., so what I am looking for is the instructions on how to remove rear door panel/power window motor diagnostics/removal/replacement.
Thanks a lot in advance.
Ray
Old Jan 27, 2022 | 05:12 PM
  #289
Kelsen's Avatar
There are some videos on YouTube -- search for "remove rear door panel 2013 acura rdx". There is also this how-to in the forum: https://acurazine.com/how-tos/a/acur...r-panel-424160
Hope this helps; it looks to be similar to removing the door panels on my former car, an Accord.
RFT!!!
Dave Kelsen
"Without faith we might relapse into scientific or rational thinking, which leads by a slippery slope toward constitutional democracy." -- Robert Anton Wilson
Old Jan 30, 2022 | 04:09 PM
  #290
RayNA's Avatar
RFT!!!
Dave Kelsen
Thank you for the tips....
Old Jan 30, 2022 | 04:52 PM
  #291
RayNA's Avatar
RFT!!!
Dave Kelsen
I tried searching YouTube and found that there are instructions for removing the rear door panel for MDX or other RDX models but I guess 2013 RDX would be pretty similar, however my real problem is with the power window (switch?/motor?). I've seen a video on an MDX that one of the windows stopped working after a battery change, and apparently there is a way to reset it. Since every model year and model has it's own little quirks, I was really hoping to find 2013 RDX specific instructions for power windows problems.
Old Mar 1, 2022 | 10:35 PM
  #292
phil_0745's Avatar
Smile 2016 RDX Heater fan/blower replacement
Dave - I could use some help in replacing the blower fan motor on a 2016 RDX. Much appreciated for the PDF if possible.
Phil
Old Mar 3, 2022 | 04:54 PM
  #293
Aspecoholic's Avatar
Hey Dave, Looking for instructions on how to remove the side pillars, ceiling liner, door sweeps, trunk panels etc. for a 2018 RDX Aspec. I know its alot to ask for but im looking to wire up a 2-CH dash cam and im trying to figure out the best path to the rear window. If there is a complete section available for all the interio panel removals that would be the most ideal.
Much appreciated!
Old Mar 3, 2022 | 06:10 PM
  #294
Kelsen's Avatar
Phil
Much appreciated!
Fellas, some time ago Dave lost the access he had to the manual through his work. I suggest you search the forums here, and if you don't find these particular problems addressed, start a thread. The other potential solution is to purchase access to the manual; I seem to recall it can be done on a daily, monthly or annual basis, and it is not cheap, because screw the consumer.
RFT!!!
Dave Kelsen
Once I was passing a roadside fruit stand, and I stopped to ask for directions. There was an old grizzled farmer there, with a face that looked like he had seen many things in his life. I asked him which way to go. He paused for a moment, then took out a handkerchief and wiped his brow. I don't know what he said, because I just peeled out. I don't have time for guys to pull out handkerchiefs. -- Jack Handey
Old Mar 6, 2022 | 12:28 AM
  #295
phil_0745's Avatar
Thanks Dave. Much appreciated for your response. I'm still a bit baffled on how difficult the system can make it to work on your own vehicle. Looks like I'll be purchasing one of their options.
Old Mar 26, 2022 | 09:39 PM
  #296
inmydream316's Avatar
Hi Dave,
do you have motor mounts replacement manual for 2016?
Old May 23, 2022 | 01:21 PM
  #297
Talking_Tree4U's Avatar
Trunk Interior / Trim Panel Remove
Good afternoon/evening Dave08902,
Could you please tell me and the rest of us how or show to replace the "Trunk interior's Panel / Trim" Please and Thank You very much!
Old Jun 9, 2022 | 09:56 PM
  #298
Tmccar's Avatar
3rd Gear
Sunroof
Looking for Sunroof Service manual. 2015. ]
Old Jul 23, 2022 | 10:17 PM
  #299
willtime's Avatar
Question 2017 rdx a spec
Will you please tell me what these wires go to on right side front also is there a yellow wire for the fog light on right side
2017 Acura RDX A spec wires right side front
Old Jul 30, 2022 | 09:03 AM
  #300
Nates NJTL's Avatar
Hi Dave,
Do you have the info for an all wheel alignment for a 2 gen RDX? Most interested in the specs / settings for Toe / Camber. Thanks much
Old Jul 30, 2022 | 09:26 AM
  #301
Kelsen's Avatar
Folks, some time ago Dave lost the access he had to the manual through his work. I suggest you search the forums here, and if you don't find these particular problems addressed, start a thread. The other potential solution is to purchase access to the manual; I seem to recall it can be done on a daily, monthly or annual basis, and it is not cheap, because screw the consumer.
RFT!!!
Dave Kelsen
In England, “booster shot” is spelled “borchestershire shot.”
Old Sep 9, 2022 | 08:22 PM
  #302
GinoB's Avatar
Hi Dave,
Would it be possible for you to post electric drawings/info, I would like to install a kill switch on a 2022 RDX A spec.
Usually it is suggested to kill the fuel pump, I was thinking of maybe interrupting the brake pedal signal since it is needed for push to start or the drive/reverse buttons on the transmission.
Reasoning behind this verses going with fuel pump is I would like for the remote start to still work, I am in the great white north it's very convenient on cold winter mornings..
I had a 2020 RDX and they stole it, I want to make it harder to steal when I get the new one.
Thanks for any help you can bring.
Regard's
GinoB
Old Sep 16, 2022 | 08:15 PM
  #303
colorsandscents's Avatar
I need the 2013 Acura RDX step-by-step instructions on how to close the moonroof manually with an allen/hex wrench. I took off the overhead console assembly but can’t find the socket to close the moonroof. I don’t have any “plugs” or see any sockets. It’s going to rain tomorrow…help…
Old Sep 17, 2022 | 08:57 AM
  #304
meburdick's Avatar
'17 RDX Tech AWD - WDP
Can't anyone update either the title or the first post in this thread to let everyone know that no more requests are possible?
Old Sep 18, 2022 | 10:38 PM
  #305
altair47's Avatar
The motor is located in the area of ​​the rear dome light and most likely you will need to lower the back of the headliner to get to it. Looks like a flat head screwdriver.
Old Oct 10, 2022 | 01:05 PM
  #306
AceWright's Avatar
5th Gear
Originally Posted by dave08902
Hello emry
Here is the service manual on timing belt replacement.
This is so great. I love you sir!!! - However, I do not know what this first part "CKP Pattern Clear CKP Pattern Learn Procedure" is all about.
I have done chain and belts in past but this seems new. Is this required and if so what is a "HDS which must be connected to DLC" I assume this is a honda computer of some sorts.
Any help or tips is great. Thanks
Old Oct 10, 2022 | 01:14 PM
  #307
AceWright's Avatar
5th Gear
Hi all,
If you need any factory service manual data, please ask here and I will upload them.
Having all the service manual data in one location helps all users on this forum to locate them easily.
If you need other vehicles, I can fulfill your request but it may take a while. I will do this for other Acura vehicles only and on a limited basis.
Hope you understand, this is the second generation RDX forum.
Thank You
Dave - you seem to know a lot about Honda/Acura.
Do you think this diagnostic tool suggested by a YouTuber (Samcrac) would work in place of the Honda HDS? Or is the procedure of CKP pattern clear / pattern learn not needed? Or will this not do that?
Amazon Amazon
Any thoughts or tips are so appreciated.
Old Oct 10, 2022 | 01:30 PM
  #308
Kelsen's Avatar
Do you think this diagnostic tool suggested by a YouTuber (Samcrac) would work in place of the Honda HDS? Or is the procedure of CKP pattern clear / pattern learn not needed? Or will this not do that? https://www.amazon.com/dp/B09KZTYD18...v_ov_lig_dp_it
Acu
There may be some folks that can help, but Dave no longer has access to the Acura manuals, and does not monitor this thread. I suggest you search this the whole 2G RDX topic for timing belt info as well. Good luck!
RFT!!!
Dave Kelsen
If I were a porn star, my answering machine message would say, "I'll be in and out all day today."
Old Oct 14, 2022 | 01:57 PM
  #309
bobgr04's Avatar
3rd Gear
rdx 2022 side mirror
Hello, Do you have an instruction on replacing the mirror sub-assembly (glass only) for this car?
Thank you in advance
Bob
Old Oct 14, 2022 | 01:59 PM
  #310
bobgr04's Avatar
3rd Gear
Bob
Old Oct 15, 2022 | 06:42 AM
  #311
altair47's Avatar
Bob
There are small hooks with which it is held on to the base of the regulator, you will need to move the mirror to the side so that there is a gap in which you can put the clipremover and carefully pick off these hooks one by one. It is enough to click off 3-4 of the eight hooks for the mirror to be removed.
Old Oct 15, 2022 | 08:19 PM
  #312
Demet's Avatar
Hi Dave,
Would you happen to have the section related to oil and oil filter changes? Most specifically I’m looking for the drain plug and filter torque values but would love the entire section on it if you could.
Thank you!
Old Oct 16, 2022 | 08:45 AM
  #313
Kelsen's Avatar
1. Dave's not here, man. He no longer has access to the Service manual, and doesn't check this thread.
2. I don't know if it would apply to this particular request, but it's useful to search this thread; there's a lot of information here.
3. I recommend avoiding the need to answer the question. If you're going to do your own oil changes, install one of these:
Fumitomo Oil Valve (Amazon) Fumitomo Oil Valve (Amazon)
. You don't take it off like an oil drain bolt. This avoids the possibility of damaging the aluminum oil pan. YMMV, of course, but I did this 25,000 miles ago on my RDX, and it has worked like a charm.
RFT!!!
Dave Kelsen
​​​​​​​I can't think of anything worse after a night of drinking than waking up next to someone and not being able to remember their name, or how you met, or why they're dead. -- Laura Kightlinger
Old Oct 16, 2022 | 01:05 PM
  #314
egads's Avatar
The specs are:
Drain plug, 29lbs with a fresh crush washer. Some folks need to go to 33 lbs because of previous over tightening.
Oil filter is 7/8" beyond hand tight. Make sure the old gasket is off, lightly oil the gasket on the new filter.
All Honda/Acura automatic transmissions require regular fluid changes. A normal fluid change replaces approx. 1/3 of the fluid.
The drain plug is 36 lbs (with a fresh crush washer)
The fill plug is 33 lbs with a fresh gasket.
Many folks rig up a funnel & hose or stacked funnels to refill through the dipstick hole. Patience is required, fluid fills very slowly.
Here is a link from the MDX section here: (RDXs 2013-2018 are just little MDXs)
https://acurazine.com/forums/ilx-382...e-plug-993434/
It also includes specs for the rear differential in AWD models.
Old Dec 5, 2022 | 03:01 PM
  #315
ogpiro's Avatar
5th Gear
RDX Passenger Air Mix Control Motor Replacement
Looking for instructions on replacing the passenger-side air mix control motor (blender motor) on a 2017 Acura RDX.. Please Help!!
Old Dec 7, 2022 | 10:33 PM
  #316
altair47's Avatar
If no one answers, then I will send pictures
Old Dec 8, 2022 | 01:07 PM
  #317
seadonkey's Avatar
4th Gear
Rear spoiler and 3rd brake light
Hi Dave, thank you in advance for your help and for this thread. Our spoiler has become loose on one side and almost halfway across to the other side. Possibly related, the 3rd brake light has become non-functional. Any service manual info you can provide on these two subjects is greatly appreciated. Cheers 🍻
Old Dec 12, 2022 | 03:36 PM
  #318
ace777's Avatar
Hi,
I need the location of the washer motor relay or relays. Not getting power to the motors but the wipers work. 2017 RDX
Thanks!
Old Dec 12, 2022 | 04:06 PM
  #319
Kelsen's Avatar
Dave's not on the forum, as he no longer has access to the Acura shop manual.
I recommend a thorough search of the threads in this forum, although someone may see your request and be able to help.
RFT!!!
Dave Kelsen
Old Jan 1, 2023 | 07:59 AM
  #320
Carmo's Avatar
Hi,
Can you post how to replace the push start ignition button for 2015 acura rdx.
I do not want to break any clips or panels as I am pulling it out. Would like to know where the clips /screws are located.
Thanking you in advance.
