Question about 105k Service
I own an acura RDX 2013 and am familirizing myself with the upcoming services. I know at 105k I need the timing belt, water pump, tensioner etc......
Reading about this on Amazon. Apparently this kit uses the same comapny that makes the OEM honda part.
Anyone have experience with this?
Would also like to get this installed with the service.
How many hours of labor should I expect with this?
The other option was to just go to a honda dealer and have them do the service. I hear Hamilton in NJ is reasonable.
I am in the CT area.
your part list looks great!
Aisin is a major parts maker for a lot of OEM equipment
the timing belt job is abig one! and the prices can range from $400-1200 depending on where you go!
a honda dealership will be on the lower side....
and an indie mechanic can even beat that price
This is what someone on Amazon posted:
1 - Timing Belt Kit w Water Pump, this is the only one I 've ever found with the OEM level water pump including the Oring tabs (see video) (this product)
1 - Drive Belt 1 - Thermostat, I got a fail safe that locks open if it breaks so I don't have any chance of overheating the aluminum block 1 - Thermostat gasket 2 - Honda Type 2 Gallon Coolant, flush not neccessary 3 - Honda DW1 ATF Fluid Quart 6 - NGK 6994 Iridium Spark Plug, Factory OEM 1 - Engine air filter 1 - Cabin Air Filter, I got an activated Carbon and Baking Soda Filter and it really makes a difference
Cabin filter and engine filter I would do myself.
All in all this comes out to $300 in parts. What do you think the labor would be on something like this?
the people that got the service done at honda dealerships for $400 did NOT go by the book for labor.
YOU will have to shop around!!!
it took me maybe 2 weeks to finish the job. and that was my first time doing it.
if you go by the book on labor hours, you will be looking at the high end of the range...$1200, sir.
Shop around.
Shop around.
Honda Timing Belt Service | Timing Belt Replacement Near Burlington, Trenton, Princeton & Freehold
This dealer does it 549 but it just says the timing belt. I want to also do everything else like tensioner, water pump, thermostat, spark plugs etc......
the belt goes through the tensioner...so in order to remove the belt, you need to remove the tensioner
and! in order to put the belt BACK through the old tensioner, you need to compress the hydraulic pin. which would need a press.
a new tensioner has the pin compressed already...and then you just pull the latch like a gernade to set the tension
Next obstacle up is trying to get warrantied on some Pirellis that said 65k warranty that I purchased at Tire rack and am at 4/32 with only 35k miles on them. I didn't get them rotated at 3-5k like they suggest but at 15k service.
Anyone have experience with that?
justnspace (02-07-2017)
Agree. I am at work though, also my car only has 80k miles on it. Just figuring out what it takes to have my car for the long haul.
theyll probably void your warranty because of that
you still have roughly 2 years or 25K before you have to do this...
