Not starting...? dead battery
2014 RDX AWD Tech
I just tried starting my car and it won't. It recognizes the key and all other dash lights appear as normal. But upon pressing the start button nothing happens. There are no error messages on the dash.
I would expect some sort of message if the battery is dead , am I right?
Damn... it would have been so much useful if had happened last week when I had to visit my dealer for a set of new tires. Just wondering what my options are since Acura is closed today and tomorrow I have to be at work.....!
2014 RDX AWD Tech
I guess I was getting too "comfy" since last week. . Now my stress level is back up again.
justnspace (01-08-2018)
Costco, Sears, and other stores have batteries too
You would think that You should hear a click or clicking if battery dead and start button pushed.Is vehicle in park?Brake switch?Do You have a voltmeter to check battery voltage?
My first thought would be a dead battery from leaving the lights on, or not closing the door tightly. However accidents like that can no longer cause problems on the RDX because of the built in power protection circuitry that will automatically shut off the headlights and dome lights after a period of time.
On the other hand, the RDX has many more computers and processors running in the background than your grandfathers Buick ever did. The result of this continuous current drain, is that the battery will not remain charged for weeks or even months like in the old days. If your RDX sat for more than than a week without being started I would still consider a week battery as the cause of your problem.
If you press the start button without your foot on the brake, your dashboard and accessories will spring to life (in accessory mode) without starting the engine. If it looks like you are in accessory mode, check that your brake lights come on when you step on the pedal. You may have a defective brake pedal switch and your RDX does not realize you are stepping on the pedal.
The RDX also has to be in PARK in order for the engine to crank over. Try to move the shifter around and retry starting the engine. I can't recall if a message is displayed to move the shifter to PARK when you attempt to start the engine, but it's worth a try.
2014 RDX AWD Tech
I tried it cranking it after a few hours and the battery powered engine revved a few times and died second attempt did not last half the duration of first one and then nothing. Only the accessory mode without any other message. The only regular message "step on brake and push button" which comes normally during start up. One thing I noticed was different though. The brake pedal felt unusually stiff like its locked very hard.
I called my neighbor for help and he connected the jumper cable and the car started fine immediately. The brake pedal felt normal this time. I drove around for some time and left it off. Now I tried to start another time and it started fine without any issues. Not sure what's going on.
All of our driver seat memories seem to be erased.
2014 RDX AWD Tech
You are right, but I'm wondering that since the car is still under warranty, Acura may decide to cover the bill.
That has been my prior experience with Honda at least. Two and a half years is a little too early for a battery to fail in my opinion.
Ahh.. see if you had that in your OP, I would have suggested wait for the dealer as well It's a 3 year replacement or 100-month pro-rated. You're well within 3 years. It may just be low on charge. Got a trickle charger by chance?
2014 RDX AWD Tech
No,I don't have a trickle charger. But this car hasn't been sitting undisturbed for any length of time. It's driven daily, even the day before this happened. My worry is that it may give up at an inopportune moment unlike this weekend while at home.
One more question.I usually keep the headlights at auto setting which turns on and off while starting and shutting down. Will that cause that much of a power loss? I'm keeping it off for now anyways.
If it happens again after being parked 12 hours or more, and you eliminated the possibility of loose cables I suspect your battery is toast
Auto headlights pose more damage to the ballast and bulb than the battery itself. The constant on and off action diminishes the overall life of the ballast/bulb. I never use Auto with HID.
2014 RDX AWD Tech
Okay guys. I visited my dealer yesterday. They checked the battery and decided that it was not holding charge. They replaced it under warranty . They showed me some graph which showed the battery hovering around 30% mark whereas the cut off was marked around 40%.
Well done Acura. I think my car is winter ready now. .
Wasn't there discussion elsewhere about Honda/Acura batteries not being up to snuff? Cheaply made? (Memories of the early-'00s V6 Hondas and Acuras with the cheap platic part in the transmissions causing thousands of failure, mine included, three times.) I'd definitely take the warranty battery but the next time I'm sure you'll be looking elsewhere.
When we came home from three months away, my TLX wouldn't start. AAA had me running in 30 minutes and left a graph of the battery starting to degrade after three years. (Not my problem, the lease ended shortly thereafter.) In Texas, batteries fail prematurely, usually in winter, because of the summer heat and high A/C usage.
2014 RDX AWD Tech
2014 with 21000 on it and all stated here happened yesterday. I did notice a week ago that she was cranking slow but would start very quickly. Yesterday brake was very stiff before pushing start button and would not turn it over. Put a new interstate in and it is just fine.
Great. My new battery is a year old now and still holding so far, sometimes the crank is tittle too long for comfort especially in really cold weather. Keeping fingers crossed.
