Fuel Filter change
Fuel Filter change
Has any one changed the fuel filter on RDX 2015? I think it is in the tank. I'm considering to replace it as I get a low mileage recently. But am not sure where it is exactly located or what the change procedure is.
the fuel filter is a sock filter attached to the fuel pump.
under normal circumstances (using premium fuels), one wouldnt need to change it very often or even at all.
the fuel pump sits inside of the fuel tank and can be pulled out, if one really wanted to change the sock filter.
on most cars, the fuel pump is located underneath the rear seats. directly where the fuel tank would be.
have you considered the 02 sensors?
lazy 02 sensors can cause horrible MPGs
doing a little bit more research, it seems as tho the sock is the pre-filter. the actual filter would be embedded into the fuel pump. which there is no way to replace it without damaging the fuel pump casing.
so, in order to change the fuel filter...one would need to change the fuel pump. and that just seems like a waste of money, unless your pump is going out.
I would look into the 02 sensor theory.
These vehicles are just fancy Honda's, they do not need to be fussed over as you seem to be predisposed to do.
If you want to do more, change the trans fluid (normal drain & fill) every other oil change. You know, once the oil life reaches 15%.
justnspace (07-06-2021)
doing a little bit more research, it seems as tho the sock is the pre-filter. the actual filter would be embedded into the fuel pump. which there is no way to replace it without damaging the fuel pump casing. so, in order to change the fuel filter...one would need to change the fuel pump. and that just seems like a waste of money, unless your pump is going out.
On the O2 sensor, I have another thread for it but no one replied. The car has 85K miles on it and I think it is almost the time to replace the O2 sensors. Tried a couple of days ago but the O2 socket I have almost stripped the sensor bolt. So it seems that the socket has spread and was no linger holding tight enough. Today, something jumped into my mind and I thought why not trying it. With a propane torch I heated the socket to a red point and then used my wise to narrow the gap. It worked out well and the socket now sits very tight on the sensor. So I will try to remove the rust around it and apply good amount of penetrating oil and then try to remove it. This is my last resort, so God be with me
I have been changing AFT every 30K miles religiously.
Altair47: So you are going to replace your working fuel pump with a used fuel pump? If the fuel pump was the issue, it would cause starting and drivability issues; not just "poor" gas mileage.
Emry: What is the gas mileage you are getting? I thought I was getting bad gas mileage in my 2017 Tech, then I analyzed my driving. I go to the gym 4 times a week and it's a mile away (yeah, I should walk or jog there....). I'm getting 10 mpg for that trip. I drive a lot in town with stop signs and stop lights. but it also can sit for 2 days if I work from home. I know I am not getting the "city" mileage that the EPA says I should get. I do a little highway driving but nothing long and sustained. That may change as we head back to the office. I'm happy with the 21+ mpg my car has registered since late November.
I bought my RDX used in late September. I didn't like the gas mileage I was getting but remember that the car had learned the original owner "driving habits". I disconnected the battery for 15 minutes. Not sure it made a difference but I'm ok with the 21+ mpg the computer is logging knowing it's based on my driving and not the original owner. That is based on about 8000+ miles of driving.
Give it a try.
If I could expand the gas tank by 2 gallons......
Give it a try.
Also check the tire pressures. This has been the primary cause of poor fuel mileage in all my vehicles. Remember stone cold in the morning before
being driven. You can also up the pressures a bit. I have been using 38lbs. all around. Here in California (other places maybe)
there is a different fuel formula used in the summer that also results in lower fuel economy.
Also, see your doctor about medications for OCD.
Give it a try.
Give it a try.
The gas prices have left me with no money for that medication. Now you know why I'm trying to get a higher MPG again.
The fuel pump is not as critical as the timing belt. Consider me cheap, but I'd rather buy a 3 year old OEM Acura fuel pump with 50k miles for $ 50 than buy a new one OEM Acura for $ 400
Well, critical in a sense that if it fails the car simply is stranded. Check rockauto, they have very affordable ones.
altair47 (07-08-2021)
I was talking about about a possible dirty or clogged fuel filter. The pump itself has nothing to do wit MPG as I mentioned in my earlier post it only may cause the car not starting.
What's the point of changing the fuel pump separately for $ 45 without changing the filter, if you can buy a housing assembly used original Acura OEM with low mileage for $ 50?
Fuel pumps don't work on Hondas because of failed solder on the main relay under the dash. That is a part worth having around.
Once the vehicle is into it's second 100k.
Fuel mileage: Check tire pressures. Cold, stone cold in the morning. And the next morning if the vehicle has been serviced anywhere.
It's up to you if you want to trust a used critical part. I don't. I prefer to use new parts unless it's a bumper or fender.
Maybe it's time you circled back to this thread This is how to get high MPG from your RDX Are you still doing everything you advocated then?
Are you sure you're not dropping in other MPG / HP boosters such as split-fire plugs, intake vortex generator, fuel line magnets or tuned your VCM to drop to one cylinder?
Could you quantify "drastically?" I'm also curious how you calculate your MPG? Are you going by the RDX's "dreammeter" or performing a manual calculation at fill-up? I ask because Acura rates the 15 RDX-AWD at 27MPG HWY and 19MPG CTY. Your MPG #'s better the factory ratings by 26% & 36% respectively...which I personally find incredible.
I do! Actually last week I drove 500 miles on cruise at a steady 70 MPH and got 32 MPG for the whole trip. On the return back I got 31 MPG. So the trick of getting high MPG is driving not faster than 70 and be on the cruise. Any other mode will impact the efficiency.
deepblue626
12-30-2009 01:05 AM
