Caliper painting 2014 RDX TECH AWD
So its been three years and my calipers are looking like crap. So I decided to paint them. Make sure to mask everything you don't want painted. Put masking tape over rubber boots covering the caliper pins. Also use high quality rust oleum Caliper Paint. Here are some pictures.
mrgold35
I did the same thing to my TSX, RDX and MDX. I went with black to hide the brake dust a little better.
Acc20yrs (04-29-2017)
This is how they looked before painting
This is how crappy they looked before painting tthem.
Finished product
This is how the finished product looks like. Pretty good I think.
900 degree caliper paimt
This is the caliper paint I used, got it at Home Depot.
Inveterate Tinkerer
Nice job Acc20! I did the same but used Duplicolor brush on ceramic and took my calipers and brackets off (didn't disconnect the brake hose though). That saves a 'lot' of masking and it's easier to get everything cleaned up.
Whatever way it's done the end result is totally worth it.
Cheers
Cheers
Cheers
Cheers
This paint is break dust resistant!
Very nice, my 2014 looks like your before picture. One thing, and I know it's stupid, but I really like the Acura cap cover on the front brakes. Too bad they nixed that for my 2017.
Acura cap
Hi yes I completely agree the Acura caliper cap is nice, I don't know why Acura did away with it on later models. I would think you can still order them online and add them yourself. It's just two bolts for what I could see. Anyway, if your calipers are looking like mine did, paint them, they will look nicer an probably protect the metal as well. Thanks for stopping by and for your comment! :-)
Another thing I did (about five months ago) was replace the stock rotors with drilled and slotted ones for added cooling. I also like the look of them, so far I have not seen any other RDX (around my town at least) with these rotors on it.
Just a couple pointers:
1. Make sure to sand all the rust off. If you don't, it will eventually resurface, regardless of how much paint you out over top. Il be honest, I don't know the science behind it (you would think the paint traps the rust in), but it will appear again. If the brakes are fairly new, you should be able to get away with sanding by hand (in your case, it looks to be removable by hand). If the rust is substantial (like 5+ years of corrosion), you'll need power tools or air tools, such as a die grinder, to remove it.
Yes, it sucks, but the #1 rule when it comes to painting is the better you prep your surface prior to painting, the better the paint will look and last. Also, wear a N95 rated mask when you are sanding. Don't inhale that stuff!! They are readily available at any hardware store, wherever they have ear plugs and safety glasses. The masks are cheap too. Like $5-7.
2. Holy paint runs, batman! It looks like you were spraying the paint on really heavy. It's better to do multiple, thin layered coats. I struggled with this when I started painting, but learned over time to consistently hold the paint can about 12" away. Your first two coats will be very thin. Don't worry. They are actually acting as an adhesion layer, and will let the subsequent coats layer on thicker. Wait about 10-15 minutes between coats.
3. It's a good idea to remove the calipers when painting them. You can hang them with a wire through one of the mounting holes. Why? Anywhere you weren't able to hit with paint will continue corroding, and will spray underneath the newly painted surfaces, causing the paint to flake off over time.
Also, push the brake piston all the way in, and then cover it with tape also. No need to paint it or the rubber seals.
4. It's a good idea to tape off the wheel studs. When you go to screw the lug nuts back on, you are effectively trapping paint chips in there, which may ruin the threads on the stud or lug nut. If you do paint them, no biggie. With just your hand, screw the lug nut on until it gets tight. Then back it off all the way, blow out the paint that accumulated, and do it again. It may take 5 times to get it all the way on. The last thing you want is to strip a thread. It's not guaranteed to happen, but it sucks if it does.
5. Consider covering everything you painted with clear coat. It will add strength to the paint, a bit of gloss and will keep the paint looking good, longer.
otherwise, happy modding! I bought those same caliper covers for my TL, but, I painted mine to match the rest of my brakes. I lightly sanded them to get good paint adhesion, then painted them. I applied a high temperature vinyl "ACURA" decal over top, to give it that OEM look again. The decals are readily available on eBay... Just make sure you aren't paying a fortune for them... some sellers are a complete rip off!!
Thanks for the pointers
