Battery replacement
2014 RDX AWD Tech
Battery replacement
My RDX battery needs replacement. Do you guys still prefer to stick to OEM or from third party such as autozone, Walmart, advanced auto parts,… etc?
Are these theirs party batteries equivalent/ worse / better than OEM (price and quality wise). Any opinions?
Stay Out Of the Left Lane
Received 1,241 Likes
My understanding is that pretty much all batteries are now being made by two or three manufacturers. Johnson Controls owns about 65% of the US market. So with this in mind, there likely isn't too much difference across the brands, but I'm sure others will be able to supply their opinions. My wife's 16 RDX still has the original battery. I used to replace auto batteries with Sears DieHards, but they are harder to find with Sear's demise, but believe they are available at Advance Auto Parts.
I last replaced my 08 TL-S battery with an Interstate Megatron Plus about 4 years ago and is still working fine. I read folks lauding the cost effectiveness of Costco batteries
Comfy (01-23-2022)
I second NBP's recommendation of the strongest interstate battery that will fit in your box. The Honda/acura batteries suck. Don't know why. If your car is still under warranty, Acura will replace it free. I did this with my wife's RDX. So, in my opinion, get the free battery if you can or find an interstate dealer near you.
Comfy (01-23-2022)
Walmart, Auto Zone, Advance Auto Parts, NAPA all make highly rated batteries. I've had very positive experience with Walmart brand. Buy the right size, CCA and get the one with the longest free replacement warranty. Where people get into trouble is buying the cheaper version which has a shorter warranty.
Good luck.
Good luck.
Comfy (01-23-2022)
2014 RDX AWD Tech
Thanks a lot guys. My warranty is long gone. Had it replaced under factory warranty about 5 years ago. I just don’t have the time and inclination to get appointment at dealerships (and take time off my work) for this anymore.
Good to know that most of them are manufactured by the same corporations. In that case there’s nothing much to differentiate between them. I got Diehard gold installed from advanced auto since that was the closest available for me. CCA mentioned is 750 with 3 years warranty which I believe is marginally better than the OEM stuff. Thanks again.
I got 14 years out of the factory fitted battery in my 1999 Honda CR-V. The battery was a Panasonic and unfortuantely not available in our aftermarket. The other factory fitted battery in the 1990 Toyota Tercel lasted 16 years, also a Panasonic. By the way both cars were sold and they probably lasted longer.
Owners must be doing something wrong. Batteries require maintenance and that is the key.
Comfy (01-28-2022)
OEM does not make batteries or oil or most products that go in their vehicles. Reputable car companies usually pick a good product over cheaping out.
I buy batteries from battery manufacturers: East Penn for my cars, YUASA for my motorcycles.
Comfy (01-28-2022)
I'm a big fan of Walmart which is rated very high. If you buy the top one, it comes with a 3 year full replacement. In FL batteries don't last long so the warranty comes in handy. Also buy a quality charger like the NOCO Genius or Ctek. Monitring my battery, I find it needs charging about once or twice per month to top up a full charge.
Since I worked in a lab evaluating batteries and battery charging systems, what makes you think those are "quality" battery chargers.
I monitored their charging algorithm on a data logger and trust me, they are nothing special. They are a charger, but nothing special. Certainly better than not using a charger at all.
I suspect that the word 'quality' here reflects the feeling that it will work longer/reliably than some chargers, rather than somehow working 'better'.
RFT!!!
Dave Kelsen
Life is short; break the rules, forgive quickly, kiss slowly, love truly, laugh uncontrollably, and never regret anything that made you smile. Life may not be the party we hoped for, but while we're here we should dance...
RFT!!!
Dave Kelsen
For a typical homeowner not looking to spend hundreds of dollars, there are not a lot of options in the retail space. I'm just saying those 2 are probably your best bet. Magic Smoke on YTube does some good technical reviews of both chargers.
Hopefully better than Project Farm whose evaluations I find pointless. Many of those on YouTube need to have a technical background and they don't. I do like Engineering Explained (car guy) on YT though.
I have a coupe of personal CTEKs (*) and a couple of Optimates that I ran a data logger on. Well they were worth $50 and not much more. I bought a Pro-Logic PL2320 upon the recommendation of the people I worked with at the government labs (I'm retired). I have not run a data logger on it yet. Nice charger though. The best that I came across is a Xantrex TrueCharge II 20A that I tested some 10 years ago. Maybe they have some newer models now.
(*) and if you had one apart because the relatively new mode switch failed, the board inside is a joke. I won't be buying one again.
Anyway, I certainly do not need them for my daily-driver cars because the factory original batteries last over 14 years. I just use them on my stored cars and motorcycles.
RFT!!!
Dave Kelsen
RFT!!!
Dave Kelsen
Just grab a 24F AGM battery from Walmart and call it a day. There's only 4 companies in the US that make AGM automotive batteries and 3 companies that make Flooded lead acid batteries. Everything is relabeled.
I have an option between Walmart EverStart brand FLA $100 2yr replacement, or $170 AGM version 4yr replacement...so trying to find out... (for my 2008 TL base)
Personally, if the car did not come with an AGM battery, I would stick to regular battery. I haven't seen or read anything that suggests spending the extra money guarantees the battery will last longer. I've had good experiences with Walmart, Autozone and Advance Auto parts batteries. I try to buy the 3 yr replacement batteries. The only battery that crapped out before the warranty was the OEM battery in my 2015 Camry. I live in PA so weather isn't an issue.
I will overcharge my FLA battery to equalize the cells now and then. That type of battery can be topped up with distilled water.
i read in a different thread here that some cars may not like AGM and can actually make them go bad real fast because of the way they're charged...is this true?
You wont need it on a 2008. Guy just tried to sell me one for my 2018 and even though it is the tech package, it doesn't have things like LKA, Start / Stop and a few other electrical goodies. I suspect you would find an AGM on 2019 and later RDX and other Acura products with Stop / Start, LKA etc.
raffijian
11-12-2012 04:26 PM
