A1 Service
A1 Service
So over the weekend A1 code popped up with 4600+ miles on the car. I know is due to needed oil change. Looking at the dealer website, they want $180 for A1 service which most of it "check this , check that". What do you folks do for A1 ... simply $35 oil change ? If only oil change is done, will the A1 code go away ? Will tech reset it ?
3G TL/2G MDX Owner
ask for oil change and tire rotation, tech will reset your MID for you. price shoud be around $70 (max) for the two items, unless you ask for synthetic oil...then it'll be around $100-ish. honda dealer might charge less. also check your dealer's website for service coupons. if you check your owner's manual....for the A and the 1...literally it's just the oil change and tire rotation. my dealer gives courtesy inspections which covers many of the items under the "B" as well.
3G TL/2G MDX Owner
^^it's a matter of how you ask for the service. A1 or oil change and tire rotation. it's the same thing. going rate for A service at my dealer is around $110-120 add $30 for the tire rotation. $180 is usually the rate for the B service.
I don't know what kind of driving you do, but IMHO 4600 miles sounds a bit early to receive a service message.
I was well over 5000 miles when I took mine in for its first oil change last week - never having received a code. In fact, I think the maintenance display indicated 60% oil life remaining.
BTW, my first oil change was free.
Thanks. Dropped off the car, oil+tire is $70. Took it to a different dealer than car came from so it was not free. Wasting half a day and driving in heavy traffic was not worth for me to save $70...
it's a car-drive it
