2018 Acura RDX Powertrain?
Old 05-07-2017, 10:26 PM
  #41
Kaputnik's Avatar
Originally Posted by mrgold35
I think we will still be disappointed when we find out what Acura has behind the curtain.
I suspect that will be the case, for those of us hoping for a theoretical "sport" upgrade like you described. Acura does not seem interested in that niche with their vehicles anymore, aka the Type S or R.
Old 05-07-2017, 10:47 PM
  #42
BC01191980's Avatar
Try to be like x3, glc, q5
2.0T and at least 7 speed transmission.
maybe use tlx 8 speed dct
Old 06-09-2017, 03:24 PM
  #43
FreddyBeach's Avatar
According to information provided here on Acurazine, the engine to be offered in the next generation RDX will be a 2.0-liter direct-injection turbo-four tuned to deliver torque at very low RPMs. It will be paired with a new 10-speed automatic. This engine is found in the 2017 Civic Type R and is rated at 300+ hp. This is the same engine that will be found in the 2018 Honda Accord replacing the V6 option.
There - this is settled!! :-)
Old 06-09-2017, 03:40 PM
  #44
snorf's Avatar
I just read the article about the 2018 accord using 4 cyl turbos and not using the 6 cyl any longer. What happens to the mainstream Honda usually makes its way to acura within a few years.
Old 06-09-2017, 03:56 PM
  #45
RDX10's Avatar
You're partially correct. You're missing one key difference and that is that the 2.0T will be the same as the civic, however it will be detuned. So look for around 250hp and 270lb/ft. It's a fuel economy play not power play with the accord.
Old 06-20-2017, 06:56 PM
  #46
I was reading an article about the new generation Honda Accord which is due to be released July 14. This article stated that the 3.5 V6 would no longer be available in the Accord sedan or coupe. Replacing this engine would be the Civic Type R (?) engine which is rated at 316 hp, however it would be detuned to about 276 hp for the Accord. If the 3.5 V6 engine is dropped from the 3rd generation RDX, this is probably the engine which will replace it.
Old 06-22-2017, 03:30 PM
  #47
srpuywa's Avatar
that's one reason we got the RDX over a Q5 - the V-6
justinjsw
08-07-2024 12:54 PM
EE4Life
09-01-2023 11:05 AM
stevenv
08-12-2022 10:45 AM
TSX69
09-06-2016 04:23 AM
kurtatx
02-15-2016 09:48 AM
Quick Reply: 2018 Acura RDX Powertrain?
