2017 Acura RDX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2017 Acura RDX Technical Service Bulletins:
TSB 16-013 - 2017 RDX: TQI Information
Applies To: 2017 RDX - 2WD
2017 RDX - 2WD with AcuraWatch Plus Package
2017 RDX - 2WD with Technology Package
2017 RDX - 2WD with Technology and AcuraWatch Plus Packages
2017 RDX - 2WD with Advance Package
2017 RDX - AWD
2017 RDX - AWD with AcuraWatch Plus Package
2017 RDX - AWD with Technology Package
2017 RDX - AWD with Technology and AcuraWatch Plus Packages
2017 RDX - AWD with Advance Package
http://www.urvi.net/forumfiles/SB/B16-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-013.PDF
TSB 16-014 - 2017 RDX: TQI of the Navigation System
Applies To: 2017 RDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B16-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-014.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2016-18 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 16-025 - Steering Wheel Noise When Driving
Applies To: 2016-17 RDX - 2WD - From VIN 5J8TB3...HL000001 to 5J8TB3...HL003353
2016-17 RDX - AWD - From VIN 5J8TB4...HL000001 to 5J8TB4...HL005430
http://www.urvi.net/forumfiles/SB/B16-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-025.PDF
TSB 16-059 - Pop or Clunk from the Rear Suspension in Cold Weather
Applies To: 2013-16 RDX - ALL - ALL
2017 RDX - All 2WD - From VIN 5J8TB3...HL000001 thru 5J8TB3...HL009835
2017 RDX - All 4WD - From VIN 5J8TB4...HL000001 thru 5J8TB4...HL015307
http://www.urvi.net/forumfiles/SB/B16-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-059.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
Applies To: 2016 RDX - Tech/Adv - ALL
2017 RDX - 2WD Tech/Adv - From VIN 5J8TB3...HL000001 thru 5J8TB3...HL006065
2017 RDX - AWD Tech/Adv - From VIN 5J8TB4...HL000001 thru 5J8TB4...HL009274
http://www.urvi.net/forumfiles/SB/B17-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF
TSB 17-016 - Front Brake Noise (2016–17 RDX)
This bulletin is replaced by S/B 19-009, Front Brake Noise and/or Front Brake Judder.
http://www.urvi.net/forumfiles/SB/B17-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-016.PDF
TSB 17-017 - 2013-17 RDX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2013–17 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-017.PDF
TSB 17-018 - 2013–17 RDX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B17-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-018.PDF
TSB 17-021 - Noncompliance Recall: 2017 RDX Certification Label
Applies To: 2017 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-021.PDF
TSB 17-049 - Brake Judder (2013–18 RDX)
This bulletin replaces S/B 16-002, Front Brake Noise and/or Front Brake Judder (2013-16 RDX).
http://www.urvi.net/forumfiles/SB/B17-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-049.PDF
TSB 18-004 - Flickering Lights, Multiple Indicators Coming On, Jerky Steering and/or Voltage-Related Fluctuations
Applies To: 2017 RDX - ALL - From VIN 5J8TB....HL009715 to 5J8TB....HL029414
http://www.urvi.net/forumfiles/SB/B18-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-004.PDF
TSB 18-008 - Navigation Showing Inaccurate Location
Applies To: 2017-18 RDX - ALL with navigation - ALL
http://www.urvi.net/forumfiles/SB/B18-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-008.PDF
TSB 18-029 - Warranty Extension: Customer Support For Front Passenger's Airbag Inflator for 2016-17 RDX, 2014-17 RLX, and 2014, 2016-17 RLX Sport Hybrid (Expires June 30, 2030)
Applies To: 2016-17 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-029.PDF
TSB 19-009 - Front Brake Noise and/or Front Brake Judder
This bulletin replaces S/B 17-016, Front Brake Noise (2016-17 RDX), and S/B 17-049, Brake Judder (2013–18 RDX).
Applies To: 2013-18 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-009.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2007-18 RDX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-038 - Steering Wheel Rattles
http://www.urvi.net/forumfiles/SB/B20-038.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-038.PDF
TSB 23-029 - Warranty Extension: 2017-18 RDX 6AT Torque Converter – DTC P0741 Stored
Applies To: 2017-18 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-029.PDF
2017 RDX - AWD
