2016 RDX spring noise when turning in the morning?
I've noticed a spring noise when turning when backing up first time in the morning. After that, the sound goes away until the next morning. I've taken the car in to the dealership - they were able to replicate the noise in the morning but said that was 'normal' because other cars on the lot had the same 'twang' sound when turning the wheel in the morning. They couldn't figure out what was wrong and said because the other cars on the lot had the same issue, it was 'normal'. This issue didn't show up until recently - I have about 1200 miles on the car.
Is anyone else having this issue?
I have a 2016 AWD RDX Tech.
I'm not sure what you mean by spring noise, but what you are describing sounds like the ABS being activated. It happens only once when you first start moving the car for the first time. Cars have been like this they've started putting ABS systems on them.
I can't beleive the incompetence of some dealers. Just because another car on the lot does it, does not mean it is normal.
I definitely have this issue. I don't have as many miles on mine as you yet but mine is new also. It did not do this for the first few weeks. It just started about a week ago and I noticed it goes away as soon as I start driving forward. It happens primarily when I am backing out of the garage for the first time in the morning as I move the steering wheel left and right. It's the exact noise of spring if you were to release it and went 'boing.' I have an AWD Advance.
Sounds like the upper strut mount bearing is not turning as it is supposed to. The suspension spring sits in rubber bushings on top and on the bottom. As you turn the wheel, the spring should turn with the strut, and the upper spring mount should pivot on the bearing.
Let's hope this is not going to be a common problem. We only have a few rdx owning forum members, so this is in no way indicative of all rdx's. But that can be a good thing and a bad thing. Between this and the rear shock fiasco....Acura doesn't look so good anymore.
Also, what is the rear shock issue that was mentioned?
Were you able to find a solution for this problem?
I am having the same issue. I am also starting to hear the same noise every so often when I brake.
Thanks!
Nope, the guys at the dealership said all the other RDXs were making the same sound in the morning so it must be normal. lol... Now I'm also hearing loud braking screeches when I brake around 20mph. They replaced the front brakes but the noise came back pretty soon after. Maybe time for a Lexus or Audi...
Ours makes a similar noise, but it happens when the car is shifted from reverse to drive for the first time in the morning. Back out of the garage, down the driveway and into the street. Shift into drive and as the car moves forward there is a loud clunk sound. Never repeats after the first time in the am.
There was an Acura Technical Service bulletin on this. Mine doesn't make a boing sound when backing out in the morning but you do hear for 2 seconds a sound when you release the breaks. I think they have to replace the pads and rotors. The dealer will always try to tell you that it's "normal" so they don't have to do warranty work. Show them the Acura Technical Service bulletin and demand it gets looked at otherwise you will take it to Acura head office.
rockyboy
05-30-2016 10:11 PM
gbrucken
05-03-2016 06:22 PM
rockyboy
02-09-2016 07:54 PM
