AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   2G RDX (2013-2018) (https://acurazine.com/forums/2g-rdx-2013-2018-404/)
-   -   2016 RDX "Setup" Button (https://acurazine.com/forums/2g-rdx-2013-2018-404/2016-rdx-setup-button-936591/)
dirleton Sep 24, 2015 03:43 PM
Need some help and, yes, I have read the manual. I'm playing with things on the new car I picked up yesterday, for instance compass calibration and zone. The manual reads "Press and hold the SETUP button until the display shows the compass setting menu." So --- where is this setup button? There is a "settings" button but pressing and holding that just gets you a sore finger. What am I missing? Please help.
Desert Ridge Sep 24, 2015 04:13 PM
Car must be running, in neutral.
dirleton Sep 24, 2015 04:27 PM
That doesn't work. Just wastes gas and still get sore finger.
Desert Ridge Sep 24, 2015 04:48 PM
I Driver 1 key inside the car? (and, Driver 2 key away from the car?)
"Settings" button should bring up a menu on the nav screen that can be engaged from the whiz wheel.
giovane Sep 24, 2015 04:53 PM
It's only for base version. On 2016 models with nav, there's no calibration. The nav should know where you are and adjust the magnetic declination zone by itself.
rockyboy Sep 24, 2015 05:04 PM
Did you try going into the Nav menu then pressing settings? My compass didn't need any setup... if I press the "i" button on my steering wheel it will cycle to a compass also.
RDX-Rick Sep 24, 2015 06:57 PM
dirleton Sep 25, 2015 12:25 AM
It would make sense that the GPS nav makes it so no fiddling is required and therefore no provision is made for said fiddling. Seems they should include a disclaimer however, like they do about clock setting.
© 2026 MH Sub I, LLC dba Internet Brands
