2016 RDX CPO - Brake Concern. Should I buy?
I am in the process of purchasing a 2016 RDX advance. The CPO report indicates the following regarding the brakes:
The left front brake pad is 6 mm
The right front brake rotor is 24 mm
The left rear brake pad is 7 mm
The left rear brake rotor is 8 mm
The right rear brake pad is 7 mm
The right rear brake rotor is 8 mm
Do these numbers indicate that the brakes need to be replaced soon????
CPO is another name for used. IF you have any doubts about the brakes you should probably take care of it BEFORE buying as it will be difficult getting anything done at their expense once you are the owner.
Front pads
Brake pad thickness:
Standard: 11.0 mm (0.433 in)
Service limit: 1.6 mm (0.063 in)
Rear pads
Standard: 9.0 mm (0.354 in)
Front rotor
Brake disc thickness:
Standard: 25.0 mm (0.984 in)
Maximum refinishing limit: 23.0 mm (0.906 in)
Brake disc parallelism*: 0.015 mm (0.00059 in) max.
Rear rotor
Maximum refinishing limit: 7.5 mm (0.295 in)
Brake disc/drum parallelism*: 0.015 mm (0.00059 in) max
Rear pads
Front rotor
Rear rotor
The following 2 users liked this post by dave08902:
DUCRDX (06-15-2019),
fcostantini (06-15-2019)
