2015 RDX AWD Tech Liftgate Stop
Today I joined the club and picked up my 2015 WPM AWD W/Tech RDX.
It seems that the power liftgate opens high enough to just touch my garage door when open. Is there anyway to adjust the stop to lessen it by an inch or so?
Thanks,
MacNH
Thanks,
MacNH
Steve
If I pull as far forward as possible, our hatch doesn't hit the garage door; but then I have to snuggle behind the vehicle to walk to the exit in FRONT of the RDX.
A swim noodle section may be your friend...either attached to the garage door panel or kept 'loose' inside the hatch and put in place as needed.
This is TEXAS...what if I had a big ole PICK UP???
You may be able to adjust the 'stop' and allow your door to travel farther along the track, making it almost fully horizontal rather than having the bottom panel at a downward angle when open. Worth a shot; but ours is still angled enough to impact the hatch when it opens.
Depends on the garage door, but on our opener there is a limit switch that controls where the garage door stops. You move that limit switch fore or back along the metal beam to control when the door stops opening.
Barb Jackson
Sep 15, 2015 02:27 PM
Charlespsu
Sep 2, 2015 09:54 AM
