my 2003 acura cl type s has a grinding sound from the engine
I recently had my spark plugs changed, oil changed and had two coils replaced. I do know what a bearing sounds like, it is not the same sound..it has been running fine, but tonight, i turned a corner, the engine light popped on, and a rubbing grinding noise started coming from the engine, not terribly loud, but enough to notice..i have noticed the slightest moisture has caused the belts to squeal, could this be connected..please bear with me, any suggestions would be appreciated.
What code is store in the car's computer? That will give you some indication on where to start.
sockr1
51
06-24-2022 02:07 PM
vegasmartin
03-20-2017 12:38 AM
vegasmartin
03-17-2017 03:14 PM
