Will these fit our cars
I know a pair of these on for DRs or High performance street tires will knock off a lot of time at the track.
http://cgi.ebay.com/ebaymotors/Mazda...spagenameZWDVW
why would u wanna use those>? they cant be very light for 15's n e way bolt and offset are good but doubt they;ll clear the breaks... get somethink ultra light in a 16 like the SSR competition and some DRs and you'll be in good shape
um.....can you not tell from my orginal post that these are just for the track. They only weigh about 11 or 12 lbs. Not plan on daily driving these, just want a pair for the track. Plus they would be way cheaper than SSR wheels wit tires.
Do you think the smaller diameter wheel and tire will reduce wheel hop? I am not sure if you are still dealing that that issue or not so I am curious.
Naw I never really have issues wit wheel hop, I think the wheel hop is a driver thing. I cut a 2.0 60ft at the track friday. The smalley lighter rims like these will free up top end speed to improve track times. Like if you tapping consistant 99mph on stock wheels, these lighter wheels will change that to maybe like 102mph.
think these will fit
http://www.ssrwheels.com/wheels/comp_x_anth.html
a lot better looking, but im sure will cost more than I want to spend just some wheels that im going to be driving on to and from the track.
Lives On BOOST
They weigh like 15.5 lbs, which is pretty light, and they look good.
How much do stock cl rims weigh?
Originally Posted by 03silvertypeS
I seem to remember someone on here having those wheels...can't remember who though or what size they were
Honestly just get SSR Comps in 17 X 8s. You'll be shaving drastically alot of weight and have more contact with the surface. I think they weigh around 14-15 lbs a piece.
TQ > MPG
FWIW you wont gain 3mph from wheels alone, unless you are running really heavy wheels already.
There are guys with 80whp more than you that barely trap 102mph.
One thing to remember is that not many companies make drag radials in skinny sizes. So, make sure you know size tire and brand you want before buying wheels.
And also, wheelhop is NOT a driver issue. It may vary from car to car, but trust me I can drive and there was no way to aggressively launch, even on DR's, without wheelhop in my car.
I doubt any 15" wheel will fit around the caliper, and not many companies make a 16" drag radial.
If you can find a 16x7" wheel in the right offset and bolt pattern, and its not real heavy then you can fit on a 245/5016 Nitto Drag radial. BFG also makes a 225/45/17 drag radial, that would also work, but prob not as well as the Nitto since the sidewall is a bit shorter and less contact patch.
Lives On BOOST
I almost broke ur 1/4 time last week, lol
I'm shooting for 12s after I get my new parts installed (Engine dampers, Greddy Emanage, Stickier Rubber). I would think it's possible seeing I got at best a 2.2X 60 and trapped at 108MPH.
TQ > MPG
no clue, im just trying to figure out what the smallest size rim will fit a Cl
on premium TL (99-03) with 16", when i balance the wheels with sticking weights, they barely clear the calipers (there are different brands of sticking weights for balancing and some are too thick, they hit the calipers.)
nanos
11-12-2015 08:41 PM
