Why do people buy 225/40/18 instead of 235/40/18?
Ugh... you already started this topic on acura-tl.com and got really good, correct responses.
So to answer your question again, why don't you refer to the topic you already started and got 2 pages of replies to:
http://www.acura-tl.com/forums/showthread.php?t=82442
Let me make this clear as day:
Stock size tires 215/50/17
Tire diameter (inches) = 25.46
Tire section width (inches) = 8.46
Tire sidewall (inches) = 4.23
225/45/18
Tire diameter (inches) = 25.97
Tire section width (inches) = 8.86
Tire sidewall (inches) = 3.99
225/40/18
Tire diameter (inches) = 25.09
Tire sidewall (inches) = 3.54
235/40/18
Tire diameter (inches) = 25.40
Tire section width (inches) = 9.25
Tire sidewall (inches) = 3.70
225/45/18 Has a larger sidewall which will most likely rub if the car is lowered. That extra 1/4" means alot. It is also over a 1/2" larger in overall diamter, again more likely to rub.
225/40/18 Has a much smaller diameter, this will make the car not appear to be as low, a much smaller sidewall too; easy on the potholes.
235/40/18 Has the closest to stock size overal diameter, the widest section width, and a higher sidewall than the 225/40.
These are all GOOD things. Overall diameter being so close to stock won't affect your speedometer or your odometer as much; widest section width means the amount of rubber you have on the road is greater; higher sidewall will protect your wheels and give a better ride.
225/45/18
225/40/18
235/40/18
billmcd
ILX
Oct 17, 2016 03:33 PM
Zonian22
Nov 14, 2015 01:20 PM
saturno_v
Oct 28, 2015 06:57 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
