tire question - need help!
hi I am a newbie, so really need your help.
My cls is still on 4 stock tires. Recently, I found out that two front tires almost wore out, so I am planning to change tires. I am currently looking at Falken azenis St-115 tire. my question is : can I keep two stock tires at the rear and only change two front tires with ST-115. I am not sure if this is ok, so need your help. thanks
Doin' da crack shuffle
You could only buy 2 tires and put them on the front.
Drive it like that until it's time to rotate your tires then buy two more tires (exact same ones) and put those on the front and the other ones in the back. Just like a regular rotation.
Don't drive out of the ordinary because performance is hindered.
Spectacular Aroma About
The ST115s are awesome tires!! I love the set I just put on my car. Quiet+good grip. tires.com has them for $104 in 235/45/17. If you get 4 you can upgrade to that size. They also have a 97 load rating. They are smaller than most 235s so they should be a good fit on the stock rims as well.
thank you guys so much for your information. I tihnk I will change all 4 of the tires. one more thing, since winter is coming, should I go for the all season Falken Ziex ZE-512 Tires or the ST-115 summer tire? are there any great difference in performance and handling? thanks!
