Sway bar bushings/end link replacement time
I have a clunking sound occurring over bumps on the driver's rear side, likely the sway bar end links, so figured after 143k on original bushings/end links for both bars, it's time for a change all around .
Are OEM Acura replacement end links and bushings for the front and rear sway bars recommended? Recommended to get an alignment afterwards or not needed?
Also probably a good time to change out the outer tie rod ends. Recommendations here? I'm pretty sure that doing these will necessitate an alignment vs. only sway bar bushings and end links, right?
I would definitely have the alignment checked if I replaced tie rods.
One of my OEM rear endlinks broke around 130k and I went with Moogs as well. I also did a Eibach rear sway and bushings. I did not do an alignment and all is well.
Former Sponsor
You should always get an alignment after replacing or adjusting any suspension components.
asahrts
09-04-2015 05:55 PM
