Replacing just 1 tire?
6spd
So I got a nail on my front driver's side tire, and it can't be patched up. Right now, I got the spare on, but put it in the rear driver's side since I read in the manual that it's bad for the diff if I have the spare on the front.
My question is, is it okay to replace the one tire with a different size? I found a 215/45/17 for a good price. I realize that the sidewall will be smaller and am wondering if this will cause any harm. How about if I go wider (225/50/17)?
I currently have 215/50/17s on all the wheels with a good amount of tread left.
Thanks.
Thanks.
Thanks.
Thanks.
6spd
Ok bump....
Can I replace one tire in the rear with a 235/45/17? Since the diameter will be the same, will there be any problems?
btw, the reason why I don't want to buy a new tire is because I'm planning to get new wheels in a couple of months, and it'd be a waste.
you can do it but you will have the problem of the car pulling to the side the new tire is on. If you get a used tire try to mach up the treed dept, that will help a lot
cammy5
09-04-2015 11:26 PM
asahrts
09-04-2015 05:55 PM
