Rear Sway Bars Interchangeable?
Hey guys, got somewhat of a stupid question but thought I would ask around. Does anyone know or have on their 2G CL a rear sway bar for an 04-07 TSX or 04-08 TL? Only reason I'm asking is because I read on a thread here before that someone said the 3G TLS sway bar is an upgrade for the 2G TL, and the 2G TL/CL are interchangeable. The reason I'm asking about the RSX is becuase I ran across a couple on ebay and don't want to buy an expensive coat rack for my garage. Any help would be greatly appreciated
Whats up with RDX owners?
IIRC my rear sway is off a first gen TSX.
So a '04 TSX (gen 1) rear sway bar would be an upgrade to an '03 CL-S (gen 2) sway bar. How's the fit?
The stock bar is 19mm solid (type S) and the TSX is 22mm solid.
civicdrivr - you seem to be in the know.
If you just want to run the stock TSX bar, you can run the stock TSX bushings. Anything aftermarket and you may be hard pressed to find rubber bushings.
marcelft
07-10-2018 06:17 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
