Need help with tire fitment for my Rim
Hi, im totally newbie at this... so i dont know what tire size i need to buy for my new rim
I have an 03 CL-S
What would be the tire size needed for this rim:
Offset: 38
P.C.D: 5/114.3
Center Bore: 73.1
Some said this but i dont know what to go with
225/45/18
225/40/18
235/45/18
help please!
I have an 03 CL-S
Offset: 38
P.C.D: 5/114.3
Center Bore: 73.1
225/45/18
225/40/18
235/45/18
help please!
Originally Posted by truexh
Offset: 38
Offset: 38
, sell them and get different wheels. However, if you don't, when you get them on, post some pics, 'cause I want to see what this will look like. Good luck!
You will more than likely rub if you're lowered. Almost positive you will. I think the lowest offset is about a +42, with a 225 wide tire. I would stick within the range of +45 and higher.
Did someone recommend this wheel size to you? Or did you just go out and buy them?
You will rub if your lowered.
Get rims that fit the car.
And the correct size to keep the speedo accurate is 235-40-18. You should only get 225-40-18 if you know your going to rub with the 235 series.
because i honestly didnt know that it will stick or not... is there any other way to not have my wheel sticking out
will it stick out with 225-40-18?
You need to find a different wheel, dude. if you already have them coming or have them, don't waste your money on tires yet.
Originally Posted by chriskh
The reason you will stick out is 1.) the wheel it too wide and 2.) the offset is too low. you need to bring the offset up to at least a 42 I think. Even with the 42 offfset, you will most likely still have problems with a wheel thats 8.5" wide.
k, thanks for the advice imma try to contact the seller and hope he let me change for a 42+ offset or return them
+42 is still not gonna work on a 8.5" rim. If you're planning to drop the car more than 1" or so 18x8.5 won't fit unless you can get a +52 or higher offset.
You either need to go with:
18x7.5 +45
or
18x8 +50
18x7.5 +45
or
18x8 +50
18x7.5 +45
or
18x8 +50
18x7.5 +45
or
18x8 +50
18x7.5 +45
or
18x8 +50
Originally Posted by htown
I like your wheels NSXNEXT
so, what is it?
[BTW 20"s on a 2000 TL =
Originally Posted by brianlin87
you're in love w/ anyone that has C2s.
if ur friend has a 8.5" wide wheel and it doesn't stick out it's probably because his offset is high enough. With your +38 offset; plan on shaving/rolling your fenders.
Why not just do it right and get the right offset?
I have 17x7 wheels with a +40mm offset and they even stick out a little with 225/45 tires. You can try, and if the wheels dont fit just take the tires off and get better fitting wheels and put the tires on. Who knows maybe they wont stick out far enough for you to dislike it.
rseb4agze
May 3, 2016 07:41 AM
merc009
Oct 3, 2015 12:59 AM
nuldabz
Sep 3, 2015 05:49 PM
