Need help with my suspension/wheel setup!
Hey guys, I have been doing a lot of searching the last few days, but really needed some specific help as I'm about to pull the trigger on the install.
So, I have a 2003 CLS auto with 80k all stock.
I have purchased a new set of eibach pro kit springs w/eibach dampers, 18x8 sparkle silver A Specs 45mm offset.
I am very concerned about rubbing with this setup. I know 235/40 is the best size tire, but it will likely guarantee rubbing on bumps. I don't mind my speedo being off, what is the best tire size for appearance and no rubbing?
225/45/18 or 225/40/18?
I'm thinking of using the continental DWS tire if that makes a difference.
I also need some help on which center caps fit these wheels. I want the raised chrome cap.
Thanks in advance!
Thanks in advance!
Whats up with RDX owners?
Youll only rub on the most extreme bumps, and with someone in the back seat.
BTW, I have the caps youre looking for - PM if youre interested.
05 NBP 6 MT
I had the same springs and 18x8.5 A specs with 225/45s...tiny rub on the back only with 4 onboard and a good bump. I'd live on the edge and go 235/40...it's what I was gonna do, but I got a TL instead.
I ran 18x8 +48mm with 235/40s. I rubbed once, and that was with a 220 pounder in the back seat. I was lowered on coilovers too.
3mm isn't going to make a hug difference.
09-17-2015 09:01 PM
