Nasty noise when I hit bumps, dips! Shocks? Wheels?
I recently had a spc camber kit put on my car. I noticed that after I got that put on and the alignment whenever I hit a dip or bump, there is a horribly sounding loud noise that comes from the front! I have axis se7en mods, 19's, comptech springs and koni yellows. The noise is much more magnified than before I put on the camber kit. What could be the cause? I was thinking about raising the setting on my shocks. Do you think that would help? But then I would have to get another alignment, right? Any input helps, thanks!
"You my boi blue!"
Raising the setting on the shocks you dont have to get an alignment if you are talking about the adjustment for the stiffness. Since you have the Koni yellows you might also be refering the the height adjustment....I dont think you would need to with such little adjustment and since they are jus the shock but I def could be wrong about that one.
merc009
10-03-2015 12:59 AM
