knocking noise in rear suspension
So this is kind of hard to explain because I am hearing a noise coming from the rear of my car and I do not know what could be causing it because really it could be anything, I am guessing it is something to do with my suspension. To start I have eibach springs and OEM struts on a 03 cl-s6. the other day i was driving on the high way (~75mgh) and when I stopped to get gas I started to hear a strange knocking noise in the rear. When I hit even the smallest bump in the road or even drive slow I am hearing the knocking noise and it sounds like something popping, I also hear a squeaking sound like something is scrapping my rotor. It almost sounds like my struts are loose or bottoming out or blown but I checked them today and they both felt fine. I also checked all of the bushing in the back and they all looked good, just a little dry rotted. If anyone has any idea of what could be causing this please shoot me in the right direction to diagnose it.
Yes I just did a simple inspection and looked at everything and tried to see if anything was shaking to make the popping noise.
OK im getting the 105K tune up very soon I will have them inspect it then. Hopefully they don't charge me too much... Also should have them install XS headers which im super excited about!
Thanks everyone!
Thanks everyone!
Sway bar bushings, this car is notorious for sway bar bushings, and it may sound like its coming from the back, but I bet you it is probably your front bushings, if you can't change them out right away, a small dab of lithium grease will hold you over till you can change them.
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
