got a set of 18X8 wheels need tires help
i bought 18x8 wheels and would like to know what is the biggest size tire that i can put on without rubbing, i know 225/40R18 are the normal but i want some wider tires. and the rims have a 35mm offset
what do you mean only +35? its a good offset and will look much better than any thing in the +45 range.
05 NBP 6 MT
I had an 03 CL-S with the 18X8.5 A-spec wheel with 225/45-18s. With Eibach springs I think it lowered it close to 2 inches, I would get a whee bit of rear fender rub with 4 people if I hit a good bump-otherwise it was fine. Not sure about the +35 offset.
braveheart
09-07-2015 08:12 AM
