g37 19s fit on cls?
Old Dec 6, 2011 | 11:54 AM
GroundedCustom's Avatar
GroundeDCustoM
g37 19s fit on cls?
will g37 19's fit on a 03 cl type s?
I know they will bolt up and you need a hub centric spacer, but will they fit?
icv only seen tl info
Old Dec 6, 2011 | 02:22 PM
aznboi2424's Avatar
I think the offset is too low. They are like +30 so you will probably rub if your dropped low and depending on tire size too.
If you are getting them, the hubcentric ring size is 66.1 to 64.1.
Old Dec 6, 2011 | 02:40 PM
StreetKA's Avatar
they would fit but it would be tight (someone correct me if im wrong)
G37 OEM Wheels Specs
Sport
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires : Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires : Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
those are heavier than our stock rims
Old Dec 6, 2011 | 05:55 PM
aznboi2424's Avatar
Oops. I must have been thinking of the G35 18s.
Old Dec 12, 2011 | 07:01 PM
DLntheCL's Avatar
whats the offset?
as far as size and width go, yeah no problem. im riding 9.5 wide, front and rear with no problems
Old Dec 19, 2011 | 07:21 AM
GroundeDCustoM
Front: 19 × 8-1/2J 1.69 (43) Rear: 19 × 9J 1.77 (45)
Tires are of concern also,the proper size would be where round 235/40/19
I was even thinkin getting two fronts and forget the staggered look,cus personally.i.feel its useless. Would that help out with a beyter fit going with 4 front rims/
Originally Posted by DLntheCL
whats the offset?
emailnatec
29
Sep 28, 2018 04:27 PM
vpasla1
Sep 17, 2016 07:24 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
ROWDY621
Sep 30, 2015 03:20 PM
Bielikb96
Sep 28, 2015 10:45 AM
