tires and wheels
Old 04-29-2003, 12:07 PM
9th Gear
brathabratha's Avatar
tires and wheels
Everybody seems to be putting on 225/45/17
Will 225/50/17 not work with the stock cls rims?
Does it look wider, as the width is 7 inches? Or would I have to change wheels to get the wider effect.
Old 04-29-2003, 12:31 PM
foe
foe's Avatar
I think they will.
boosted is best
NSX-Tuner's Avatar
Re: tires and wheels
If you're going with Michelin Pilot Sport A/Ss, then IMHO, the 225/50ZR17s are the best fit for stock rims because they are spec'd to mount on 7 to 8.5 inch rims (see more info here) . Where as the 235/45ZR17s are spec'd to mount on 7.5 to 9 inch rims. Forget about the 235/50ZR17s cause the have an outer dim. of 26.6 inches. Also, the 225/50ZR17s are 0.6 inches bigger in the outer dim. over the OEMs. However, I only see a slight difference on the speedo - 80 mph on speedo is really 78.2 mph. I've noticed a very slight increase in gas mileage without any perceived performance hit. And there is NO rubbering at all (under hard cornering, bumps, etc...), even with the CT springs installed on my '03 CLS 6sp.
As for other tire brands, not sure about 235/45/17s
Old 04-29-2003, 01:28 PM
Moderator Alumnus
YuppieCL's Avatar
235/40/17 is the closest wheel size to factory spec according to the wheel/tire calculator
Old 04-29-2003, 02:11 PM
fender4's Avatar
My calc. shows 235/45/17 the closest ????
Old 04-29-2003, 02:26 PM
Administrator Alumnus
Scrib's Avatar
I have 225/50s and they're fine for me...
Old 04-29-2003, 03:43 PM
an adult perspective
Six Shifter's Avatar
Zapata has 225/50's on his stock rims, which I saw Sunday in Philly, and they look very aggresive - especially when compared to the OEM Mich's. I'm still planning on going the 235/45 route since these are overall closer to OEM spec, plus AllMotor sent me some pics of his 235/45's on the stock '03 -S rims and they look great! Nobody who has mounted 235/45's on stock 17's have reported any problems of any kind.
Old 04-29-2003, 06:59 PM
Moderator Alumnus
YuppieCL's Avatar
DRAT thats what i meant! my bad
Old 04-29-2003, 07:01 PM
Moderator Alumnus
YuppieCL's Avatar
i have 235/45 mounted on a stock 01 wheel... no problems at all
Old 05-02-2003, 08:46 AM
lely's Avatar
Does anyone have any experience with contiextreme tires?
Old 05-02-2003, 09:36 AM
Cajun Gumbo Man
Fabvsix's Avatar
I just ordered a new set of S03 in 225-45-ZR17 at 174.00 each. Awesome tires ! Isn't summer here ?
Old 05-02-2003, 01:25 PM
tdtsai's Avatar
To go from 50 series to 40 series tires, you really should change the wheels to 18". This is the standard Plus One upgrade without compromising the speedo accuracy
Old 05-02-2003, 02:50 PM
[DWI]'s Avatar
I've been through the stock MXM4's and a set of S0-3's (BTW I loved the tires copletely awsome just don't last as long as I'd like, but they stick to the bitter end, mine look like slicks right now and are still great tires)(245/45R17) at 34,000 miles. Right now I believe the next set of tires I will get will be a 235/45R17 Firestone Firehawk SZ50 EP, does anyone know anything about them?
KB1_EJ6
11-13-2016 09:51 PM
GhostTL09
09-19-2015 01:57 PM
cammy5
09-04-2015 11:26 PM
nuldabz
09-03-2015 05:49 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: tires and wheels
