CL Suspension question
You underdig?
I had a 99 accord before my CL. I modded it with the rear stock CL-S sway. Its a popular mod for the 6th gen Accord to get good increase in stiffness for only about $60. And, it did just that for me.
Now that I have the car to go along with the sway
... I'm a little disapointed. The handling of my Accord with the CL-S sway bar was considerbaly better than the boat like ride I get with the CL-S. And my CL-S has a 1.5 inch drop with Bridgstone Potenza rubber and Tokiko adjustable shocks. Anyone have any idea why? I would think it would get better. Could it be the 3-4 hundred pound weight difference? I don't know much about the stock suspension of our rides so...
And, can anyone give any suggestions on what I should do to improve it? Strut tower bar, bigger sways, what?
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
I was looking at the Eibach sways, I think I may do those over the Comptech.
STB I'll probably get CT... I saw a Neuspeed one that was one piece and Im curious to know if that was better. Im sure it doesnt make much of a difference. Does anyone know if DC Sports makes a STB for our CL-S's.
nitelyfe, how do you like Tokiko adj's?
Not Asian
You underdig?
Thanks for your help. Does anyone know if the stock sway is 19mm?
They're OK. I have the fronts set to 5 and the rears to 4. I'm thinking of dropping the fronts to 4 cause its too friggin bumpy. They've been on there for over 1 year and I haven't had any problems.
Location: Somewhere between here and there, yet neither.
Which potenzas did you get? Your dampening is probably too soft...and yeah the sways will create flatter cornering....your CL should stomp your old AV6 in every way.
You underdig?
I agree my CL should be better in every way. By the way, I had the F23a4. Not the V6.
Originally Posted by nitelyfe
I'll have to look at the exact tire specs later today. I never can remember. I wanna say they're 225 50 18 and I think they're ZR rated.
Anyway, the sways should do the trick...
BoricuaTL
04-08-2016 01:08 PM
