buying new tires for cl-s wheels
Old 09-10-2007, 08:42 PM
Airborne MP 16th Unit
dasuddith33's Avatar
Cool buying new tires for cl-s wheels
would a 245/40/17 fit with no problem i want a lower side wall fatter tire or 215/45/17 or 225/45/17 can u help please ...
Old 09-10-2007, 09:16 PM
Silvaccordex01's Avatar
225-45-17 you can do 235 but thats a bit wide for a CL
Old 09-10-2007, 09:17 PM
would dat 235/45/17 rub
Old 09-10-2007, 09:33 PM
It shouldnt but why would you go that wide?
Old 09-10-2007, 10:02 PM
CL-Pride
ironsurfer129's Avatar
225/45/17 will work, but your mileages will be off. When the speedometer shows 100 mph, your actual is probably 97 mph, and it will causes ur odometer to go off as well.
Old 09-10-2007, 10:11 PM
so other than 215/50/17 stay stock tire size.... thanx for da feedback ...
Old 09-10-2007, 10:44 PM
hmmmmmmmmm jus a thought wat bout 215/50/17 in da front but 245/40/17 inda rear watcha think or jus 215/50/17 all round
Old 09-11-2007, 08:07 AM
fuzzy02CLS's Avatar
May want to all search this subject.
The correct up size is 235-45-17. There's ZERO problem running this on CLS rims. You will not ever rub since the rims are +55 offset.
I've had 3 CL's & each had at least 2 sets of 235-45-17's.
Old 09-11-2007, 11:33 AM
Don't Mess With Texas
cltypeSLOW's Avatar
thats correct if you run stock height, or a mild drop. anything lower than that and you will rub. htown tried it out.
Old 09-11-2007, 11:34 AM
cltypeSLOW's Avatar
why dont you use dat lil search function up der at da top dawg. just buy 235/45 all around. end of story.
Old 09-11-2007, 11:39 AM
fuzzy02CLS's Avatar
On stock CLS rims? I never heard of that. Even dropped 2+inches.
Old 09-11-2007, 04:16 PM
SOLD: 03 SSM CLS Auto
gaping46and2's Avatar
I'm running 235/45 on my TSX rims which are also +55, same as stock, and have a 1 finger gap and I've never rubbed. If it was slammed, I could see the potential of rubbing in the back.
Old 09-12-2007, 10:11 PM
AARONSredTYPE-S's Avatar
i am about to put neuspeed race springs on whih are a 2.2" drop and i was wanting 235's, so you think it would be fine?
Old 09-13-2007, 08:01 AM
fuzzy02CLS's Avatar
I do & would try it. That's me though.
GhostTL09
09-19-2015 01:57 PM
cammy5
09-04-2015 11:26 PM
nuldabz
09-03-2015 05:49 PM
bailey24
08-31-2015 05:38 PM
blownby
08-31-2015 12:44 PM
Quick Reply: buying new tires for cl-s wheels
