anyone install a camber kit?
Enjoy the Ride
I was wondering if anyone here attempted to install a rear camber kit on there car. if you have pls send me a link on instructions. thanks
Moderator Alumnus
Not Asian
Originally Posted by mantis23
Just a couple more things.
1. When going to Autozone, make sure you get the ball joint separated and not the pitman arm. The pitman arm is a little to big and won't really wedge under the ball joint.
2. It is very hard to tighten the pivot bolt with the wheels on the ground. Don't tighten the brake bracket back. Put the wheels on, put the car on the ground. Reach around and tighten the pivot bolt. Raise it back up and tighten the brake bracket back in place.
3. You will need to jack up the hub to tighten the ball joint bolt back into place
It's very simple to do and I'm glad I didn't pay someone to do this.
Are there any DIY with pictures for the Ingalls rear camber kit? There are a couple of steps I am not quite sure about, that could be clarified by pics of the install or even if anyone has pics post install. Something that would show where the silver/black jam nuts fit in.
666 Speed
1 Post
Originally Posted by smokendsm
I'm pretty sure its as simple as you described it. You don't even need to mess around with ball joints..
Alright thanks...
I'll play with it tomorrow and see..
Maybe i'll do the DIY...
666 Speed
1 Post
Originally Posted by m733l
i just did my last week. out with the old and in with the new. now i just need to take it to get them aligned.
Good to know.
Going to do it tomorrow.
Thanks guys
It was definitely pretty easy to do, just swap them out. The only issue you *may* run into is that the bolts won't crack open, soak in PB blaster before you attempt to open them.
cycdaniel
12-17-2019 10:58 AM
nuldabz
09-03-2015 05:49 PM
