18x7.5 in 48mm vs 18x8.5 in 52mm offset
Wondering which i should order. i am on Koni/neuspeed sp3 shocks and neuspeed sport springs. Would the 8.5 in 52mm require fender rolling. i am willing to do that if i need too. Also is a 235/40-18 tire not wide enough for the 8.5 i assume.
I called tirerack an hour ago and they had 1 set of the 18x7.5 in silver left. Just called back and someone just bought 2 of them so i cant get those now. There is only 1 set left of 18x7.5 in black and 2 sets of 18x8.5 in silver. So i can either get 18x7.5 in black, 18x8.5 in silver, or i can mix 2 18x7.5 plus 2 18x8.5. This is for s ilver car, what do u guys think.
3.5 psi
silver. check out mine:
https://acurazine.com/forums/album.p...ictureid=12372
Thnx for the replies guys i made a decision and placed my order. I ended up going with http://www.tirerack.com/wheels/Wheel...All&sort=Brand these wheels in silver 18x8.5 52mm offset. The tires i got are
http://www.tirerack.com/tires/tires....el=Ventus+R-S2 in 235/40-18. The wheels were $299 a piece and the tires were $89 each. I think i got a great deal and will be very happy with the purchase come spring. Ill probably roll the back fanders just to be safe. My rear right fender is already kinda wavey and disformed so rolling will help.
Bye Bye CL!!!
I may be looking into running somewhere near the same specs maybe in 19's, just waiting to wear my tires out before I get a new set of wheels. I'm dropped about the same, maybe even a little lower than 3 inches... Your car looks great bro!
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
