Yay electrical problems!
This started happening about a couple weeks ago.
Once in a while (maybe every 10-50 miles) the electrical system just sh!ts out. Everything turns off...but one for a split second and then comes back on as if nothing happened. (Gauges drop, CD player stops, lights go out, etc...). Whats a bit weird is that the engine doesn't actually skip a beat.
I am going to go tighten the terminals and ground connections tomorrow, but I just can't imagine its as simple as that. Anyone come across something like this before? Thoughts?
'03 ABP YA4-S 6MT
anyway, see here.
https://acurazine.com/forums/showthr...light=ignition
it could easily be the ignition switch. it's not just for starting, you know.
anyway, see here.
anyway, see here.
On a side note I now have a thing to check for my mom's 95 Altima that just stopped on her while driving a few days ago & won't start back up now. It has fuel & spark, & tries to turn over.
Restored this in 1998
This would happen on Acura Vigors pretty regularly, its the only time an Acura left me stranded. Short story the solder on the wiring that connects the interior fuse box to the the ignition switch gets hot and I actually found drops of solder on the carpet.
Under Combination Switch Part #9 $52.17
http://www.hondapartsunlimited.com/
Did you look at the part I referrer to in the URL? I mentioned it was a common Vigor problem, the CL shares the same design. It isn't the Ignition Switch itself but the wiring that connects the switch to the Fuse Box.
that happened to me a bunch of times and i tightened the terminals as well. but it didnt fix the problem. turned out there was an incredible thin layer of corrosion around the entire inside of the terminals that was causing the problem for me. make sure you take them off and wire brush them clean!
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
joflewbyu2
10-08-2015 11:16 AM
rboller
09-23-2015 02:49 PM
