what turbo kit can i put on my 01 type s cl
Subscribe
Sep 19, 2010 | 05:09 AM
i have a 01 cl types and i want to put a turbo on it but i cant find a kit made for that car i can find super chargers but thats not what i want, i want speed and gas not just speed all the time . what if any car and year would have an interchangeable turbo kit
Reply 0
Sep 19, 2010 | 07:35 AM
No turbocharger kits available only custom setups.
Reply 0
Sep 19, 2010 | 08:21 AM
https://acurazine.com/forums/showthr...ighlight=turbo
here is a setup for sale in the black market.
Reply 0
Sep 19, 2010 | 03:19 PM
aw man cause i heard that a honda accord turbo might work but i never installed or had a turbo kit so i wanted to make sure before i bought it that it or another turbo kit might bolt up
Reply 0
Sep 20, 2010 | 02:54 PM
A turbo kit on a CL Auto is like making a bridge out of Corn Flakes then trying to drive over it with an Abrams tank.
Reply 0
Sep 20, 2010 | 04:07 PM
What civic said.
Or, actually, these are universal, so they would work -----> http://cgi.ebay.com/ebaymotors/Elect...#ht_7996wt_941
Reply 0
Sep 20, 2010 | 08:00 PM
zac no just no i would never put that vacuum cleaner stuff on my car
Reply 0
Sep 20, 2010 | 09:50 PM
Youre new, so I wont get on your case too much, but red text indicates sarcasm.
Reply 0
Sep 20, 2010 | 09:55 PM
Quote: Or, actually, these are universal, so they would work -----> http://cgi.ebay.com/ebaymotors/Elect...#ht_7996wt_941
:bronzecup
Reply 0
Sep 21, 2010 | 08:43 AM
Quote: A turbo kit on a CL Auto is like making a bridge out of Corn Flakes then trying to drive over it with an Abrams tank.
Funniest thing you've said in a while. lol
Camjones-Let me give you some real world advice. Do not attempt to put a turbo on your CL, for so many reasons. There is no "bolt-on kit", its not gonna be that easy... Actually it's going to be a frigging nightmare. Currently on this board only 2 or 3 people are running a working turbo kit. There are hundreds of CL members, so do the math. Once a month or so a new member comes on here and says they are going to turbo it, and do a rwd conversion, and do a 3.6 swap. Blah, Blah... they never come back with any results. EVER!
You mention you've never owned or installed a turbo kit, RED FLAG number 1. Is this your first car? If you did manage to get one on there say goodbye to reliability, extra cash, and your glass transmission. My friend is going through the turbo blues with his car right now. Granted it's not a CL but he has not driven his car consistently in a year and a half... the day he started the turbo project.
I commend you on your desire to mod your car, there are lots of options to feed your need for speed. If I where you I'd consider a 6speed swap. Intake headers and a pulley kit gives this car like 30hp, nothing to laugh at... If you really want a turbo pick up an old DSM or a Subie. Good Luck
Reply 0
Sep 21, 2010 | 11:23 AM
If you go with a DSM, make sure you get a 6 bolt engine not a 7 bolt. That is unless you want to learn to be a very good mechanic, then get the 7 bolt.
http://www.urbandictionary.com/defin...term=crankwalk
Quote:
My dsm crankwalked on me, but thankfully my dsm has broken down often enough to make me a real mechanic.
Reply 0
Sep 22, 2010 | 02:13 AM
slick no this isn't my first car my first car was a 99 ford ranger 3.0 loved that truck but it sucked gas so i got my acura and idk for the cost of a 6 speed swap i would just sell the car and get an 03
Reply 0
Sep 26, 2010 | 12:07 AM
Its not that hard to do a turbo swap. Just dont get too carried away and pust 30psi boost. I am currently building up a custom kit for a rear mount. Just do alot of research. I plan on runing a gt3076r on 6lbs boost. Very conservative and is able to be daily driven. Good for about 350 the very least.
Reply 0
Sep 26, 2010 | 01:06 AM
his tranny is going to blow in 5...4...3...2... lol.
Reply 0
Sep 26, 2010 | 10:38 PM
^ +1
Reply 0
Sep 27, 2010 | 09:37 AM
Hmm, I wouldn't run boost on a stock motor...I'd build it up a little bit and make sure EVERYTHING is boost ready before you just jump in, or bad things can happen...
Boost causes problems and is a huge money pit. But I would def recommend it, as I have personally seen what the J series can do on boost. Just do a lot of research and be ready to spend.
Reply 0
Sep 27, 2010 | 10:32 AM
Quote: Hmm, I wouldn't run boost on a stock motor...I'd build it up a little bit and make sure EVERYTHING is boost ready before you just jump in, or bad things can happen...
your giving him bad info. its not the motor thats the problem its the tranny. if your so intent on putting a turbo on an automatic at least swtich the tranny to a TL or oddessey tranny. if not i 110% garauntee it will blow.
Reply 0
Sep 27, 2010 | 10:44 AM
There is so much more you can do before even considering a turbo
Reply 0
Sep 27, 2010 | 10:47 AM
Quote: There is so much more you can do before even considering a turbo
But if you are considering a turbo that should be taken into account before doing anything else. No sense in buying a bunch of parts that will need to be replaced if you are going to add boost.
Reply 0
Sep 27, 2010 | 12:16 PM
A stock motor can handle around 7psi of boost. ThinJim was running 7psi IIRC on a stock motor. The auto tranny wont hold that power for long. And even the stock clutch wont last that long before it starts slipping. 7psi is over 400whp.
The axles wont be able to put up with it for long either.
If you want to run more like 10psi, a mild build should be considered.
Reply 0
Sep 27, 2010 | 01:01 PM
LOL
Reply 0
Sep 27, 2010 | 01:07 PM
Quote: A stock motor can handle around 7psi of boost. ThinJim was running 7psi IIRC on a stock motor. The auto tranny wont hold that power for long. And even the stock clutch wont last that long before it starts slipping. 7psi is over 400whp.
this is correct because i am running 6psi right now and the stock clutch went bye bye in no time.
Reply 0
Sep 27, 2010 | 01:13 PM
CB, ever get your car tuned?
Reply 0
Sep 27, 2010 | 01:16 PM
Quote: CB, ever get your car tuned?
yeah i messaged u when i was up there in july to see if there was anything goin on. i took it to tempest in Md he did a good job but of course everyone hates the greddy blue because its not really user friendly.
Reply 0
Sep 27, 2010 | 01:24 PM
Quote: But if you are considering a turbo that should be taken into account before doing anything else. No sense in buying a bunch of parts that will need to be replaced if you are going to add boost.
True but if you still plan on going boosted don't buy parts that your going to have to replace. I kinda meant options like an engine build or 6 speed swap.
Reply 0
Sep 27, 2010 | 01:46 PM
Quote: yeah i messaged u when i was up there in july to see if there was anything goin on. i took it to tempest in Md he did a good job but of course everyone hates the greddy blue because its not really user friendly.
Any numberes? Finished pics? I dont think we've seen it since paint.
Reply 0
Sep 28, 2010 | 08:53 AM
Quote: Any numberes? Finished pics? I dont think we've seen it since paint.
yeah i got the dyno chart at home i got still runnin 6psi ish cause its never really exact at about 350ish. The painter that did it in Va Beach was a shade off on some of the lip kit so i have my friend up here matching it up so i can put it back on then i will have the pics up. Finally got the wheels on it too
Reply 0
Oct 19, 2013 | 06:44 PM
nice
Reply 0
Subscribe
