What part number for a plastic clip?
http://i513.photobucket.com/albums/t336/hermtm2/q2.jpg
Hello. This is the engine room on 2001 CL. Does anyone know the part numbe of the plastic clip in where the red circle is on the picture? Or if you have it, I would like to buy it. Thanks. |
17926-sm4-941
$3.44 |
No, that was what I order (I have it). I thought the number was that but it turned out wrong.
It should be:
http://www.acuraoemparts.com/delray/...s3m0_b2310.gif 004 17926-SM4-941 CLIP, THROTTLE WIRE (BLACK) 1 2003 CL 4.58 3.44 |
Does it look like the clip that goes on the radiator? The parts diagram doesnt show and when I look at the intake flow tube I see the right clip, its just not listed. It appears that you can replace it because its not part of the intake top cover.
I don't get it. What do you mean "its not the part of intake top cover" ? Where can I get the clip? I know that the #4 on the digram is not what I am looking for becuase I have it right now.
i dont understand. the part you circles is number 4. and since you have that part in your hand, does it look like number 4 in the diagram?
Yes, the part what I've got is the same look but that is not the same as the clip on the picture. They are totally different shapes.
http://i513.photobucket.com/albums/t...rmtm2/clip.jpg
I just took the clip out from the filter cabin. As I mention, it has a totally different shape to the clip on the part diagram. Anyone know where I can this clip? |
are those all pics of the old one? it looks like the same as in the diagram.
what does the new part look like? |
No... The part in the new pic had an arm originally to hold the wire. The arm was broken that why I want to buy. If you open your hood, you can see the clip with an arm. However the part on the diagram can hold the radiator hose which means the diameter of the clip is much wider than the old one.
Also if you look at the diagram carefully, the clip is too big to hold the wire. I think the clip on the diagram is for a radiator hose underneath the airfilter cabin. Thanks. |
I swear it looks just like it. well if your confused, I would go to your local acura parts dept and have them give you a part number on it or order it right there.
http://i513.photobucket.com/albums/t...mtm2/order.jpg
This is my invoice. I ordered the part as the diagram but it was not the same as the picture I posted later. Please believe me. I understand why you confuse because I did but they are different. I just send the part back to dealer today. I should have taken a picture of it. |
Originally Posted by hermtm2
(Post 11998381)
I just took the clip out from the filter cabin. As I mention, it has a totally different shape to the clip on the part diagram. Anyone know where I can this clip? Now if you can find the Air box system and its components on the parts website, that might be where it could be found, if it can be purchased separately. |
It looks like #3 on the diagram.
Don't you guys think? |
(Post 11999250)
Don't you guys think? Look at #3 in the link below, which is in regards to the MDX Auto Cruise, looks very much like the unbroken part in your picture. 17882-P8C-A01 CLAMP B, WIRE http://www.acuraoemparts.com/delray/...All&vinsrch=no |
I think you found it.
Thanks. |
