Unsteady feeling going into a curve at highway speeds
Need help finding out a problem with my CLS6. So far I've changed the radius rod bushings, endlinks, sway bar bushings, lower control arms, upper control arms. Ball joints are ok, have front and rear camber kit, alignment done(pretty much perfect castor a little off) newer tires. Its on BC coilovers and they are in good shape and were readjusted. It's a 2003 Acura CL 6 speed. At highway speeds when I'm driving into a curve car doesn't feel steady. Seems like it's the front end. I have the same year TL with twice as many miles and that car feels fine. Anyone know what else it could be?
Heck
only thing I could take a guess at is the steering rack. I have an 01 cl-s and three miss matched tires lol and two different tire sizes on front and back. Normal ride height and new sway bar bushings, end links, front lower ball joints, cv axles, k frame, inner and outer tie rods, motor and transmission mounts as well. The car has 312,120 miles on it and I can take a tight corner at 65 and not break contact with the road.
whitetiger5 (02-10-2020)
fracas
07-31-2013 07:35 AM
