Squeaking noise when i turn left or right
today i heard i squeaking noise when i turned left and right...i thought the noise was coming from both sides....i turned all my electronics off and realized it was only coming from the right..b4 i did anything i came on acurazine.com to do a lil research...some say tie rods, some say axles, some say power steering ball .....after reading all this.. i jacked up my ride...inspected all the bushings. checkd the endlinks, checkd the axles for wear checked the upper ball joints, check the outertie rod, i moved everything around(shook it to see if something was loose)....then i found my answer. in my case it was the bump stop. it is located within your springs, on your shocks. mine are torn. so for the time being i just lubed it with oil. i dont hear it anymore. itll b my project another day......I HOPE THIS HELPS OUT THE NEXT GUY> and not waste your money on sh*** u ddnt need.
Phambam12
09-05-2015 04:10 PM
