Side Mirror Replacement
Old Apr 13, 2011 | 05:42 PM
ufool's Avatar
8th Gear
Hey guys,
So the other day I hit a trash can in my 2001 Cl. As a result I broke my passenger side mirror glass and sub-assembly. I can find the glass no problem, but when I went to look for the sub-assembly I became confused. I went to this site; http://parts.sonsacura.com/showAssem...roduct=1632928. In their listings they have two different sub-assemblies. One is 76203-S0K-A21 and is listed for the 2001 cl. But there is another one 76203-S3M-A21 (heated) which is for the 2002+ cl. I am unsure which part to get because I have a 2001 cl, but it also has heated mirrors. I looked for a part number on the old broken sub-assembly, but could not find one. Can anyone provide any help??
Old Apr 13, 2011 | 05:54 PM
civicdrivr's Avatar
By definition, the sub assembly is the glass. Are you looking for just the glass or the mirror assembly as well (the painted surface)? What color is your car?
Old Apr 13, 2011 | 06:08 PM
ufool's Avatar
8th Gear
I need the plastic piece that the glass is mounted in. I believe it to be part #2 in the link I posted.
Old Apr 13, 2011 | 06:14 PM
civicdrivr's Avatar
#2 is pointing to the glass. #4 appears to be what you are looking for, its called the actuator assembly. PN 76210-S3M-A11
Old Apr 13, 2011 | 07:21 PM
ufool's Avatar
8th Gear
What i need is the plastic piece that holds the glass and plugs into the actuator assembly. Is the sub-assembly just the glass? Maybe I need to get the piece from the dealership?
Old Apr 14, 2011 | 03:22 PM
aznboi2424's Avatar
Looks like the glass plugs directly into the motor. There's probably some plastic behind the glass and its probably a single part along with the mirror. Best is to check it out in person at the local dealer then order it online.
csmeance
Jan 7, 2026 06:25 PM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
sockr1
Oct 1, 2015 01:31 AM
Skirmich
Sep 15, 2015 06:41 PM
PortlandRL
Sep 14, 2015 12:01 PM
