Severe power loss in 3rd gear ONLY
2003 cl type-s 6spd
1st and 2nd gear are very strong, then i shift to thrd and the rpms are unusually low with very little throttle response, but then in 4th the car gets all its power back. Any ideas? Clutch or tranny? I just bought it but I assume it's had a rough past.
If I am pulling through gears hard and shifting in high rpms (around 7k) then 3rd gear doesn't even catch and it smells like burnt clutch. If I shift normally from 3500 rpm it always shifts but I can instantly feels the power decline and rpm always drops to around 1100 - 1300. I will attempt to get a video later today.
justnspace (03-10-2017)
Thanks for the replys! I'll definitely start with replacing the cat. I looked it up and they seem to be fairly cheap (around $150) so either way I imagine it would increase throttle response in all gears, especially if the stock one is clogged.
