broke bolt
Old 06-18-2010, 03:31 PM
3.7L Nitrous Breathing CL
richardparker's Avatar
broke bolt
Riped apart everything for p2r thermo upgrade and broke a TB bolt in the manifold.
I assume using 3 bolts would create a leak or will it ?
I thinking I'm going to drill it out if not.
Has anyone now/before had only 3 TB bolts and no leak ?
Old 06-18-2010, 04:49 PM
Jacobpockros's Avatar
I think you should make your own Build thread and post all these questions in there rather than make a new thread every other day
Also, I would answer your question but i do not have an answer for it
Old 06-18-2010, 05:15 PM
So why say anything ?
It's all together now and it seams to be fine idling.
I have not taking it for a ride yet but,there's no flucuating rpm's.
And while it was apart the whole intake and TB was cleaned again.
Old 06-18-2010, 05:18 PM
I am saying this because it reduces clutter. I myself have my own build thread that i use to post all my questions in.
If i were you i would do it right and get a new bolt to replace the broken one
Old 06-18-2010, 07:03 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,143 Likes on 4,810 Posts
Do you have any threads visible? If you can, lock two nuts onto the bolt and and unscrew it from the manifold.
Old 06-18-2010, 07:15 PM
I did do that thats why it snapped .
It came all the way to the threds are just barely sticking out the back.
A couple more turns and it would've been all good.
Old 06-18-2010, 07:44 PM
Moderator Alumnus
BigLizard's Avatar
One bolt isn't going to hurt. I did this on accident to my ol' cl. I didn't fix it till miles later. Never had any leaks.
Old 06-18-2010, 08:35 PM
Regional Coordinator (Texas)
nspec_ya4's Avatar
use a chizle and a hammer and spin it out.
Old 06-18-2010, 09:49 PM
OG 3.x^7 rawr
SPoolinspOON's Avatar
cut a slot and use a flathead
Old 06-18-2010, 09:51 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Being on the TB i would replace it. If it starts to leak you are going to have serious RPM issues.
Old 06-19-2010, 01:39 PM
aznboi2424's Avatar
i did this to one of the manifold bolts on the engine. luckily when I took off the mani, i had half an inch of thread so I screwed it out with locking pliars. but i bought an extractor kit just incase i needed to take it out that way
Old 06-19-2010, 04:28 PM
2000 acura tl FPR
assclown's Avatar
i over torqued a bolt when installing my pressure plate and broke the head off it. so now i have threads stuck in my flywheel. i plan on using an "easy out" to get it out. just havent had time to deal with it.
tsx_boy
12-13-2019 08:33 PM
polish_pat
09-30-2015 12:22 PM
juanrl
09-29-2015 03:25 AM
xsilverhawkx
09-28-2015 06:51 PM
ROSSARONIE
09-22-2015 11:46 AM
Quick Reply: broke bolt
