Road Lamp un-wiring question
To many cars in my garage
It is wired in parallel with your hids so it depends on what you are doing the easy way is to cut
now im not sure if you have to do this but I got in to an accident a while back. Ripped off the bumper and my hid fog setup was in the middle of the road smashed no collision either. So anyways I had to fix it my self but on the back I noticed my drivers side HID headlight was not coming on but as soon as I installed the new balllast to replace the one that was broken the head light came on
So what Im saying is when you cut it there are two red wires on the passengers side you may need to attach these together
Shouldn't be that hard to get under the car and trace the wires back. They're probably spliced into the driver side headlamp because they are only functional when the head lights are on.
Just becareful because if the dealership wired them up to factory specs simply disconnecting them may cause the headlamp to not function.
When I removed the lamps from my '02 CL-S the driverside headlight wouldn't work until I reconnected everything.
Registered Abuser
i suggest you just tell him to buy his own wires and plugs.... much less of a headache for you to just sell the roadlamps and not the wires.... i never heard of anyone selling the wires and risk damaging ur electrical system.....those wires are deep into the headlight wires.
09-17-2015 09:01 PM
