Question about replacing a timing belt
Hello.
I just bought 2001 CL which has 110k on it. The previous owner didn't told me about any maintain history. I guess the factory timing belt is still on the cranks.
I've read several articles about replacing timing belts. As the articles, the owners usually replaced a couple of parts related to the belt instead of only t-belt. Is it necessary? The parts are below.
timing belt
water pump with gasket
timing belt tension adjuster
timing belt tensioner
timing belt idler
both accessory drive belts
front crankshaft seal
two front camshaft seals
Thanks.
timing belt
timing belt idler
Thanks.
The TARDIS is my
if it has 110K and hasn't had any of those things replaced, and it says to do them at the same time. then yes. do it.
and also, welcome to Azine, read the n00b threads.
Whats up with RDX owners?
Lol, its the FAQ thread.
wusty23jd
09-24-2015 11:41 AM
Phambam12
09-05-2015 04:10 PM
asahrts
09-04-2015 05:55 PM
