please help
Easy, there's a screw in the corner that holds each in. At the bottom front grill, up near the top corner there will be a little slot. Use a long handle Phillips screwdriver & insert it into this slot. You will contact the screw holding the vent piece in. Unscrew it. Then reach your hand through the bottom grill & push out the vent.
